invert the whole piece, now the camera will be on the left side, remove the camera from the assy(2 screws) so you can rotate it 180 degrees(if not the camera is pointing up and you cant mount it)position it a little bit down around 4mm( medyo mas masikip na kasi yung area na yon) then screw it back. mount the whole thing , thats it
Thank you sa tip sir zix. Actually, planning to replace the camera module too kasi nawala yung lines sa nakakabit ngayon, buti na lang may extra pa na unit..
drained my OCC after 13000kms, was able to trap 90ml of oil. last time was 50ml for just 3000kms, maybe because hataw mode then, or something to do with the oil i am using now
At NLEX early tonight, I went neck and neck with a 2007 CRV. Was following his tail, even reached a top speed of 170kph. I was so proud of my Monty. Very stable and still had power to speed up. Just ran out of road. Tanggal carbon sa SCV, hehe.
Maligayang Pasko sa lahat ng Monty owners, ke 2010, 2011, 2012 o 2013 model man.
Yahoo and keep on enjoying the drive!
merry xmas proud naman ako sa monty namen umabot ng 15.2km/l city/hway![]()
Sir, tried doing this during the weekend in my 2012 GTV. Mukhang magkaiba tayo ng model ng back-up camera. In the 2012 model, the camera itself cannot be removed and rotated. One piece assemply type. I was able to remove the 4 screws at the back cover of the camera and saw that it was fixed and part of the assembly. I was thinking of interchanging the plate 2 lights, i.e. light with camera transferred to the right, but the wirings were too short. Besides, di tayo sanay gumalaw ng wiring...hehehe.
- - - Updated - - -
sinubukan ko rin pero iba din yung camera ko
Although pwede matanggal yung camera sa casing at i modify ang mounting ng screws sa camera to frame..
I tried to co.pare my camera to your gtv. Magkaiba nga. Mas malaki lens ng gtv mo while my camera mas maliit. Sensya ka na medyo nahuli ko gtv mo sa freeport hehehe
- - - Updated - - -
- - - Updated - - -
Texted u sa sun number. I guess naligaw text ko. Hehe nice mags u got there. On the way back to manila that time
- - - Updated - - -
