tama ka sir, 900 pesos lng yung bayaran ko sa labor, im now looking for aftermarket differential oil and transmission oil.
Tama sir diba, grabe makataga ang casa eh. Take note po pa clean nyu nadin ang egr nyo
Inquire ka kay sir zix88 expert siya jan sa egr, most people pinapa blank nila what i heard is mas ok ang sasakyan, though didnt do yet sa unit namin.
Share ko lang. Going 11. Next project will be rock sliders, roof rack and sound system upgrade.
Hi Guys,
Sino naka quicklift sa inyo? My rig is a 2013 Strada currently riding on Black Rhino with +12 offset. Tires are 265/50/20 and are about to wear out. I'm planning to avail of the 2" quicklift (coil spacer sa front then spacers sa rear), will not change the shocks muna as I will wear them out muna before I change to after market shocks. My question is, after ko mailagay yung 2" quick lift, kasya na kaya ang 275/55/20 tires without any rubbing issues? Thank you sa mga sasagot, mas maganda kung galing dun sa same setup na iniisip ko para sure![]()
With a lift, I think it will fit.
Here's a tire size comparison chart, so that you will have an idea on comparing tire sizes.
Tire Size Comparison
Mga bossing na naka glx v or equivalent engine, ano yung radiator cap specs ng stock at kung nagpalit kayo?
Does anyone know the exact open length of our oem rear shocks? Part number is MRR992632. Planning to upgrade to Rancho kasi parang nabitin sa haba yung oem shocks after the lift. Rancho 9000xl part number 999350 open length is 23.79 inches. TIA.
Hi Guys, update ko na din question ko since I've already got an answer. OEM full length is 21". To those who will put rear shackles with 2" inch lift and will use OEM shocks, this is not advisable, shocks length will be at 19.75" (18" with no lift) inches when parked on an even surface, meaning you only have 1.25 left for rebound with OEM, not advisable and will destroy OEM shocks in less than a week (based from my experience). Already changed my rear shocks to Rancho 9000XL part number 999116. Full length is at 23.75", compressed length is 15.1", just right since my shock length at rest is at 19.75". I have 4 inches for rebound and almost 5 inches for compression. Hope this helps to those planning to do a two-inch lift. Btw, I also measured Ridemax (the white one) full length is at 22". Thanks.
Question lang mga boss i have a mitsu strada 2010 model 4m41 engine, gusto ko kasing palitan ang steering wheel nya into aftermarket, kapag pinalitan ko pwede pa bang ma retain ang srs airbag nya? Medyo marami ng gasgas yung steering nya at hinde na maganda ang status ng leather.. Any inputs mga bros..
I replaced the rear shocks after the quick lift using Rancho. Kaso after a few months, nagstart na din magleak yung front (sulit na din because it has almost 90k kms on it) kaya I upgraded to Lovells coil springs and Ridemax 4-way adjustables. If incase you need front coil spacers, message me and I can sell it to you at a lower price, I don't need it anymore kasi naka Lovells na ko.
