Results 4,971 to 4,980 of 5002
- Nov 2014
- 91
March 23rd, 2017 04:10 PM #4971
March 31st, 2017 05:20 PM #4973
With a lift, I think it will fit.
Here's a tire size comparison chart, so that you will have an idea on comparing tire sizes.
Tire Size Comparison
- Oct 2008
- 64
April 15th, 2017 08:50 AM #4974Mga bossing na naka glx v or equivalent engine, ano yung radiator cap specs ng stock at kung nagpalit kayo?
- Nov 2014
- 91
April 16th, 2017 09:24 PM #4975Does anyone know the exact open length of our oem rear shocks? Part number is MRR992632. Planning to upgrade to Rancho kasi parang nabitin sa haba yung oem shocks after the lift. Rancho 9000xl part number 999350 open length is 23.79 inches. TIA.
- Nov 2014
- 91
April 24th, 2017 09:02 AM #4976Hi Guys, update ko na din question ko since I've already got an answer. OEM full length is 21". To those who will put rear shackles with 2" inch lift and will use OEM shocks, this is not advisable, shocks length will be at 19.75" (18" with no lift) inches when parked on an even surface, meaning you only have 1.25 left for rebound with OEM, not advisable and will destroy OEM shocks in less than a week (based from my experience). Already changed my rear shocks to Rancho 9000XL part number 999116. Full length is at 23.75", compressed length is 15.1", just right since my shock length at rest is at 19.75". I have 4 inches for rebound and almost 5 inches for compression. Hope this helps to those planning to do a two-inch lift. Btw, I also measured Ridemax (the white one) full length is at 22". Thanks.
- Jul 2010
- 1
June 11th, 2017 08:24 AM #4977
June 24th, 2017 09:37 AM #4978
Question lang mga boss i have a mitsu strada 2010 model 4m41 engine, gusto ko kasing palitan ang steering wheel nya into aftermarket, kapag pinalitan ko pwede pa bang ma retain ang srs airbag nya? Medyo marami ng gasgas yung steering nya at hinde na maganda ang status ng leather.. Any inputs mga bros..
- Jun 2007
- 46
January 27th, 2018 05:15 PM #4979
- Jun 2007
- 46
January 27th, 2018 05:17 PM #4980
high idle RPM at engine start
