Page 22 of 250 FirstFirst ... 121819202122232425263272122 ... LastLast
Results 421 to 440 of 5000
    May 2007
    #421
    Makikiraan lang po to greet everyone a,
    HAPPY NEW YEAR!
    Jun 2007
    #422
    [SIZE=4]TO[/SIZE][SIZE=4]
    [SIZE=6] ALL STRADA OWNERS[/SIZE]
    [/SIZE]
    [SIZE=4]IN THE TSIKOT FORUM[/SIZE]
    :boom1: [SIZE=7]HAPPY NEW YEAR[/SIZE] :boom1:
    [SIZE=4][SIZE=6]to one and all
    ! ! ![/SIZE]
    [/SIZE]
    :bounce1: ===:rave: ===:bounce1:
    Dec 2008
    #423
    [SIZE="7"]H A P P Y N E W Y E A R TO ALL[/SIZE]
    Dec 2010
    #424
    sir beni, unichip from speedlab medyo expensive,49K with harness. Sayang nga 2 years ago, 33K lang yung complete set, hindi ko pa kinuha kasi under warranty pa ung strada ko that time. anyways baka meron maka pag point sa akin kung saan meron ibang alternative na friendly sa wallet. TIA
    Sep 2004
    #425
    Quote Originally Posted by tikboy200046 View Post
    Lets wait for the Durian TSCPs to give inputs, I heard meron sila ginamit that is less than P10K
    Jan 2011
    #426
    Happy new year to all Strada gurus, I've been reading this thread for almost 2 months now, nabasa ko na din ang 972 pages na naka archive, that is why instead of getting the 2010 Hyundai Tucson I opted for a Strada. In a couple of weeks I will be getting my Strada GLX color gemstone gray. I am very grateful for all the informations that I have read here with regard to the Strada. But I have few questions, I hope the experts may spare their precious time
    15inch rim vs 16 inch rim
    1. If I will use 15inch rim with 15x31x10.5 tires instead of 16 inch rim with 265x70xr16 AT, would there be any difference in the handling and comfort? does it void the warranty?
    2. What are the advantages and disadvantages of a 15 inch rim with 15x31x10.5 tires as compare to 16 inch rim with 265x70xr16 AT tires?
    - I know one advantage if I use 15 inch rim, it is cheaper than the 16 inch as well as the tire.
    -pareho lang ba ang diameter ng 15x31x10.5 tires and the 265x70xr16?
    - I've read somewhere na may gumamit ng 15inch rim pero di pwede mag wheel balance???!
    My intention is gusto ko lang to have a macho look on my glx, (not necessarily offroader) but at the same time save on budget. Ang budget ko pa la sirs on a new rim and tires is 60k-70k. Thank you and HAPPY NEW YEAR TO ALL!!!
    PS
    am from davao i hope ma meet nako soon ang mga members ng strada club durian team.
    Jun 2007
    #427
    try mo sa eBay
    Power Box CR diesel tuning chips para sa Triton or Pajero available for 2.5 and 3.2 engine(common rail) 270usd kasama na shipping walang tax kasi envelope lang ang pinaglagyan at hindi bulky na box. Plug-n-play no splicing na gagawin.
    Dec 2010
    #428
    sirs av8or5, shakatak... salamat po!
    how about this one mga sirs, meron na bang nag install sa mga co-strada owners...
    http://www.racechip.de/racechip-chip...-D-3800-r.html
    mas mura ito...pero mas oks yung pro model, mas mahal nga lang...
    cheers
    Oct 2004
    #429
    Quote Originally Posted by Secret_service View Post
    1. If I will use 15inch rim with 15x31x10.5 tires instead of 16 inch rim with 265x70xr16 AT, would there be any difference in the handling and comfort? does it void the warranty? -Haven't tried 16 inch wheels with 265/70r16 ATs, pero I like the ride of my 31x10.5r15 especially when the need to drive over side curbs/gutters come.-
    -pareho lang ba ang diameter ng 15x31x10.5 tires and the 265x70xr16? -Yup, parehong 30.6 inches diameter.-
    - I've read somewhere na may gumamit ng 15inch rim pero di pwede mag wheel balance???! -Tatama ata ang stick-on wheel weights. I can't even insert my little finger between the rear drum brake and the inner wheel rim. Pero baka pwede gawan ng paraan.-
    My intention is gusto ko lang to have a macho look on my glx, (not necessarily offroader) but at the same time save on budget. Ang budget ko pa la sirs on a new rim and tires is 60k-70k. Thank you and HAPPY NEW YEAR TO ALL!!! -15x9 inch Mamba Type M5 (P33K set), Cooper Discoverer ATR 31x10.50r15 (P5.9K each), 12x1.5mm chrome lugnuts (P800 per set of 16).-
    PS
    -PM nismo26 of TSCP Mindanao-Davao. Hope to meet you din, sir.-
    Jun 2008
    #430
    Mga sirs just an advice po there are a lot of chips available in the market, im not saying this because i have my own but, you will not have an upgrade of HP and Torque if you boost is still the same (14.7 psi. standard boost) you will only spend money for the same power. Just save up and upgrade with the proper chip that really gives you what you want. Not even a boost surge will be visible until your boost cut control is not modified.
    Just Save up for the proper upgrades the good ones is a bit expensive most of the times.
    Aug 2007
    #431
    PS
    pm me sir, maybe si bossing makatulong sa iyo...
    hopefully nextweek meron kaming eb..
    Oct 2009
    #432
    happy new year!!
    Oct 2004
    #433
    Quote Originally Posted by dadz View Post
    Baka ganito lang ang effect ng iba, sir:
    http://www.sprintboostersales.com/
    http://www.sprintboostersales.com/whyitworks.cfm
    P18K ata dito sa CDO. Pero I find it too expensive for its throttle-only effect.
    Jun 2008
    #434
    Quote Originally Posted by doy View Post
    Sir As long As the boost cut sensor are still unmodified hindi ka lalagpas nag 14.7 psi. So kahit annong lagay na chip if your boost is still stock pressure the hp and toque are still limited sayang lang pera. I have done this already kaya alam ko ang feeling hehehhehehehehehe.
    Just save up for the proper modification, para naman ma sagad ang power nag ating STRADA.
    a 1psi of additional boost if good enough kesa sa wala.
    #435
    sprint booster sells for 15k here sa area namin. Sabi ng installer all it does is to modify the signal from the throttle para mas ma aga yung response, di daw affected yung ecu.
    imo, i'd rather save for a proper chip than buy that.
    Jan 2011
    #436
    Thank you sir doy, for your prompt reply, asa pud ka nakapalit sa imo mamba wheels and the Cooper tire sir, thanks again!
    I'll pm you sir nismo kung makuha ko na glx ko and ma produce ko na din ang budget for the new rim and tires.
    #437
    Quote Originally Posted by jubs00 View Post
    i believe they sell the sprint booster here in banawe qc at 5,000.
    Aug 2007
    #438
    merong mamba sa carmate and metrosound dito sa davao sir...
    Oct 2004
    #439
    Mamba wheels from Michiba, Osmena St tapos Cooper tires from Transway Sales Corp., Kauswagan National Highway. Do check out the wheels at Carmate and Metrosound dyan sa davao.
    Oct 2004
    #440
    Quote Originally Posted by KCboy View Post
    Whoa! Pwede na yan i-benta dito for P13k each.
2010 Mitsubishi Strada [continued 2]
