Results 431 to 440 of 5002
January 2nd, 2011 04:57 PM #431
January 3rd, 2011 05:45 PM #433
Baka ganito lang ang effect ng iba, sir:
http://www.sprintboostersales.com/
http://www.sprintboostersales.com/whyitworks.cfm
P18K ata dito sa CDO. Pero I find it too expensive for its throttle-only effect.
January 3rd, 2011 05:58 PM #434
Sir As long As the boost cut sensor are still unmodified hindi ka lalagpas nag 14.7 psi. So kahit annong lagay na chip if your boost is still stock pressure the hp and toque are still limited sayang lang pera. I have done this already kaya alam ko ang feeling hehehhehehehehehe.
Just save up for the proper modification, para naman ma sagad ang power nag ating STRADA.
a 1psi of additional boost if good enough kesa sa wala.
January 3rd, 2011 06:10 PM #435
sprint booster sells for 15k here sa area namin. Sabi ng installer all it does is to modify the signal from the throttle para mas ma aga yung response, di daw affected yung ecu.
imo, i'd rather save for a proper chip than buy that.
- Jan 2011
- 2
January 3rd, 2011 08:47 PM #436Thank you sir doy, for your prompt reply, asa pud ka nakapalit sa imo mamba wheels and the Cooper tire sir, thanks again!
I'll pm you sir nismo kung makuha ko na glx ko and ma produce ko na din ang budget for the new rim and tires.
January 4th, 2011 07:37 AM #437
January 4th, 2011 07:38 AM #438
January 4th, 2011 11:58 AM #439
January 4th, 2011 11:59 AM #440
