My piece of advice, don't be alarmed when the warning lights goes on basta't hindi "nabibilaukan" ang acceleration mo ,you have plenty of time to bring it to casa for check up. In the manual ,it says that whenever you have this problem ,immediately park your car & have it check by expert that put you in the panicky situation, relax lang.
RTS
sir, ask ko lang ano po best rear backup camera sa 2012 4x4 gls sport strada na pwede i-connect sa built-in monitor ng strada? san po ako makakabili? hindi po mavoid warranty if pakabit sa labas? Thanks.
mga sir..
san po makakabili ng hid h11 6000k bulbs lng.. bulbs lng need ko.. TIA
meron bang way na mag palagay ng HID na hindi na void ang warranty?
at panu maging member ng TSCP!
list ng mga nireklamo ko sa warranty(casa)
1. steering wheel control
2.squeeking sound
3.wipper blade na nag vivibrate
4.ung aircon pinacheck lng hehe
so far im lovi'n my strada vgt.. masarap sa tengga ung whistling sound ng turbo from 1.5-2k rpm! *1500 milage
Hi!
Our family is currently in the market for a new pick up.
Currently we've been offered the 2011 GLX MT and the 2012 GLX MT, what are the differences between the two?
Same lang ba sa GLX-V ang difference (ABS and immobilizer)?
Thanks in advance.
Moderator's note:
all flame-baiting and out of topic posts shall be deleted.
thank you for cooperating.
di na katakataka...
lalo na't nag tanong pa kayo, so they're assuming pati kaya alangan.
so lalong madaling sabihin sa kanila na void (those guys would have you out of the warranty as much as possible).
eto ang suggestion ko na pwede niyong gawin (esp if you dont care about your relationship naman with the agent):
just tell them na lang derecho na you know for a fact na di mavovoid yung warranty dahil you know Strada Club members from the online community who have done the same thing, di voided ang warranty.
MUCH LESS in your case, na sila pa mismo ang trumabaho.
Or di we have to escalate the matter pa ba to your higher-ups?
sabay close with a "thank you"
dalwa lang yan: either bigla siyang mapaparely (which yon naman ang hinihintay niyo in the first place). or he'll take what you said (in that case just 'document' that you sent that particular piece of communication to them and where no response where made).
--292. Marco
Parang gusto ko nga banggitin yung strada club pero diko na sinabi dahil di naman ako member at naisip ko na wag
gumamit ng name ng group baka sa huli ako pa mapasama.. Sa tingin ko naman ok narin na sa kanila ko ipinakabit
pero just in case na magka problema saka ko nalang ilaban na may warranty.. Feeling ko naman di naman magkaka problema
dahil sa maganda pagka wiring at walang pinutol na wire from original wiring at may fuse naman so nothing to worry
naman po siguro.. Anyway sir thanks sa simpatya.. Ang problema now wala pa time para ibalik yung strada kasi may work
ayaw na mabuksan ng door ng bed liner mukhang may nalagot or nag malfunction na mechanism sa door..
Thanks at nasali ako dito sa tsikot.com madami ako natututunan at mas marami pako malalaman.. Thanks po sa lahat..![]()
sir kingtooth
how much po ang charge ng casa sau about sa busina?
sa 4 mos kong back read sa mga strada forum before ako na convinced bumili ng glx-v
share ko lng to
regarding sa warranty...
anything that involves drilling sa body (metal), voids the warranty on rust.
so kung mga stick ons lang (like cladding)
or screws lang sa existing na butas (bullbars, flares, etc.) ok yan.
anything that splices the electricals or would burden the alternator,
void na rin. so kung may sariling line,
with relay and fuse, and hindi mabigat ang kuha ng kuryente, ok din.
anything that exceeds 17" mags will void the warranty on suspension.
so kung 17" ang mags and super laki ng gulong,ok lang
anything that involves unauthorized engine modification, void na rin warranty dun
heto ang important... what the casa dont know,
will not void your warranty hehehe... gets???
hope it helps! :P
sa busina ko sir pinakabit ko sa trusted suki kong electrician ginamit ko ung lumang bosch na horns ko ang nagastos ko lahat kasama na lahat ng wires, socket, relays, terminals, bolts.. 400 pesos walang splicing na ginawa
tpos naglagay din ako ng h4 wiring harness plug and play lng cya para sa healights nagpalit kc ako ng 100/80w na osram allweather galing din sa dati kong pickup
walang splicing.. socket lng
ang next na ipakakabit ko ay ung HID ko sa nabenta kong sasakyan para sa fog lights
tpos nung 1k pms ko ang ginamit kong oil ay semisynthetic muna (shell hx-7 5w-40) tpos sa 5kpms ako mgpapa fully synthetic based sa back read ko madami d2 ang gumagamit ng mobil 1 turbo diesel truck 5w40.. at nakacancvas na ko ng 460/L
before ako nag pa pms ng 1k
tinawagan ko muna lahat ng dealers direct agad ako nag inquire sa mga service advisers nila
tapos hinanap ko san ung pede magdala ng sariling oil na di ma void ang warranty
thank fully meron malapit samin, na pedeng magdala ng sariling oil at di ma void ang warranty as long na i follow mu ng viscosity rating nila na required.. ang bili ko sa hx7 5w40 ko e 1300/4L, ang pinadala skin ay 8L
When my strada still under the warranty, pinalagyan ko ng busina sa third party shop, wala naman silang say (Quezon Ave), they check the wiring kung pulido, the only thing that I was told to refrain is to install Oil Catch, hintayin ko lang daw ma expired ang warranty.
RTS
What is an oil catch can
Yan hindi ko rin maintindihan bakit ma-vovoid warranty kung may OCC.Eh wala namang nagbago sa flow ng blow-by gas from the valce cover eh.
Fasten your seatbelt! Or else...Driven To Thrill!
Okay na yung door handle ng bed liner namin adjustment lang ginawa kaso kailangan
na palitan yung mga double sided tape nawala na kasi yung mga dikit mga nag angatan
yung plastic cover hehe.. Hanap nalang siguro ko pag napunta ako ng ace hardware..
Kamusta na mga ka strada diyan mukhang tahimik yata..
