Page 40 of 151 FirstFirst ... 303637383940414243445090140 ... LastLast
Results 781 to 800 of 3019
    Aug 2010
    #781
    Quote Originally Posted by rensom View Post
    Tol... san ka nagpa-installed? Kasi nag-order din ako sa Alibaba hehe.... nasa EMS na at may tracking number na ako.
    I had the cam installed by our local casa here in Cebu. Installation just took more or less an hour and a half.
    How is the performance of the back camera at night when there is not much ambient light?
    I still have to test this one out. Just had it installed this morning. I could probably give a feed back on this tomorrow night. Hopefully it turns out well.
    #782
    Mga tol.... Yung Power steering ninyo ganoon pa rin bang kagaang? Kasi yung sa akin.... syempre naka-idle ang engine tapos yung tire pressure ok naman 32.. pero pag ginagalaw ko yung steering medyo mbigat na... di paris ng dati.... Ok naman ang transmission oil... worried lang ako kasi yung engine oil since nagpa 1k PMS ko low ang level niya.. kaya ng pumunta ako sa service center low nga kaya dinagdagan nila... image nag-kasya ang 1 liter.
    Bro, ang alam ko yung asx natin is motorized ( electronic) power steering siya..di tulad ng convetional na power steering which uses hyrdraulic ( power steering fluid) and naka coupled sa engine..i think walang kinalaman yung power steering ng asx sa makina...gaanu kabigat manibela kapag iniikot mo?para bang walang power steering?..nagpalit ka ba ng mags?if not, dapat ang e checked sa asx mo is yung motor na nakacouple sa steering column mo..baka may loose connection lang somewhere dun..
    yung level sa dip stick sa engine natin bro has 2 indicators, isang low at isang high..normally yung level ng oil in the morning, w/o starting the car is above half nung 2 indicators...nasa "low" indicator na ba yung oil mo?how low is your "low" at your dip stick?maybe kaya di sinagad ng service tech yung oil mo is that mahirap sumobra langis sa engine kesa magkulang but not as low as the low indicator..
    #783
    Quote Originally Posted by cta2 View Post
    another observation/question....
    I know how a CVT works (though Im still not used to it)... My question is, if I use the paddle shifters, will the car go faster (in a straight line,) than just flooring it and just place it in Drive?
    I have a heavy foot and the only time I appreciate straight line is on stoplights... though I know the car can handle corners.
    as I understand it, the 6 speed paddle shifters are just virtual or a simulation of gears... medyo psychological ba yun speed kung paddle shifters ang gamitin?!
    The asx is a bit slow in my eyes or feel :-( but maybe because Im not used to the CVT
    Also, the car does not like revving (if I use the paddle shifters to hold on virtual gears), a bit surprised considering its MIVEC... (BTW - I also have a Grandis with MIVEC) it revs beautifully
    Any thoughts?
    Thanks
    Baka sanay ka lang sa malaking makina bro?...hehehehe...and isa pa, ang alam ko 4 peed lang cvt ng grandis compared sa asx na 6 speed..siguro may difference din sa ratios yung dami ng gear simulations..kasi basing from my experience, comparing the cvt of the asx sa a/t ng fortuner, changing from D to 3 (fortuner) and from a high to a lower gear ( asx cvt), mas favor ako sa cvt..although syempre iba talaga hatak nung 2.7 vvt-i compared sa 2.0 MIVEC na makina.
    #784
    Quote Originally Posted by FoundOnRoadDead View Post
    Nasa between H and L yung level na nag-checked ako between ng 2 hole.. dinala ko nga sa Peak Motors... dinagdagan nila.. Kaya lang nagtataka ako kasi last 1k PMS ko last March lang at april umalis ako ng 3 months noong pag uwi ko..nag-check ako lahat pati tire pressure bago ko ilabas ang sasakyan ko... ayun nakita ko ganoon na nga. wala namang leak sa garage.... kaya now sabi skin ng technician observe lang daw.... this weekend aalis ako nag-llong driving kaya malalaman ko pag uwi ko kung nabawasan nga ng oil... yung sa steering... ganoon din obserbahan ko rin. Thanks parekoy.
    #785
    Mas makakatipid ba ng gas kung gagamitin ang CVT?
    #786
    Siguro, pero kaunti lang effect sa fc nung paggamit ng manual mode sa cvt..nakadepende pa din yun sa pag apak mo sa accelerator and sa traffic..
    Feb 2011
    #787
    I also have the Grandis and it is a conventional 4 speed AT not a CVT
    Mar 2003
    #788
    Im not doubting the speed of the shifting, actually magaling nga ang asx...
    Its the straight line, (or basically 1st gear if you hold it)... parang ayaw umakyat ng RPN, or mabagal umakyat... I just hope its psychological rather than being plain slow.
    My expectations are tempered... a matic Altis 1.6, though slow, revs nicely... a heavier CRV 2.0 feels faster... But I just hope its only a feeling...
    anyone knows the acceleration of ASX (0-100km)?
    BTW - its not a complain, just an observation.
    Im sure it translates to better mileage... but sometimes, you also want to drive fast :-)
    Aug 2004
    #789
    The ASX is actually quicker than most 2.0s in the class (0-100 km/h) and quicker than even some 2.5 ATs... at least until 80-100 km/h, after which the more powerful cars start to pull away.
    #790
    0-100kph is around 11 seconds for the ASX 2.0 CVT
    #791
    My back-up camera arrived today via EMS.
    #792
    Tol...san mo balak ipa-install? Feedback parekoy
    #793
    Still deciding. If the casa at valle verde or kay sun-x...
    #794
    May thick white smoke ba na lmalabas sa tambutso mo bro?..pero sobrang aga nama para kumain ng langis yung makina mo bro...baka di talaga na fill ng maayos yung engine oil mo nro kaya ganun...
    #795
    Wala namang lumalabas na usok...
    #796
    Nag-order na rin ako ng Mud guard at LED Door Sills sa Ali Express para isasabay ko na sa pag-install ng Reverse Cam. Kaya lang noong 17th ko lang na-recieved ang Tracking Number... pero hanggang ngayon wala pa.
    * Aeye... tol sa iyo after mong ma-recieved yung Tracking Number mga ilang days pa bago dumating yung item mo?
    Thanks
    #797
    My item arrived a week and a half after the confirmation email.
    Talking about my item, here is some pictures of my ASX's rear camera.
    No night shots yet because I just got it installed today.
    #798
    Maganda..... maliwanag... hopefully by next week ma-recieve ko rin yung sa akin. San ka nagpa-installed?Magkano? Yung sa akin isasabay ko na lang sa LED Sills para isang tanggalan na lang ng plastic hehehe.
    #799
    Had it installed at SUN-X. P400 for labor.
    But I still have an issue with the rear camera trigger, it doesn't. Putting the shifter in to "R" supposed to trigger the HU to display the camera feed but it doesn't. I have tried the HU's config without success.
    Currently I have to manually select camera view if I am to use the rear view camera. I plan to drop by Mitsubishi if I can't find a solution.
    Anyone with a wiring diagram for our stock head units? I need to find that "reverse-gear" trigger wire to properly activate the camera mode.
    #800
    Any Feedback on the night vision of your rear cam? thanks
2010 Mitsubishi ASX Crossover
