Results 401 to 410 of 3019
- Nov 2010
- 301
March 13th, 2011 08:41 PM #402
- Nov 2010
- 301
March 13th, 2011 10:13 PM #4053000k or 4300k (di ko maalala between the 2
) na all weather sana yung e iinstall kaso naubos stock nung papakabitan ko last stock na nya yung nilalagay sa fog light ng montero kaya i opted the 6000k...pinakita nya sakin yung HID na ininstall nya sa montero..kulay yellow yung ini- emit na light, hindi ba masakit sa mata yun like the usual yellow halogen fog lights ( ex denji or piaa)?
- Feb 2010
- 106
March 14th, 2011 12:27 PM #407^ CVT talaga ang biggest problem sa project na yan sir.
Now, kung may 4wd version na M/t, nako..time for me to show the money.
March 14th, 2011 12:46 PM #408
March 14th, 2011 12:53 PM #409
I'd rather do this to the FWD MT ASX. For a number of reasons:
1. The CVT is a real power-killer, especially from a dead stop. If it detects too much torque going to the box, it pulls timing, causing the engine to bog.
2. The AWD system is just extra weight. You don't have the fancy limited slip differentials that the Ralliart has, that causes the car to go into a neutral stance midcorner while on-throttle.
3. You can buy a performance clutch for the MT if you burn the stock one out. The CVT is a bit more complex. You'll need a transmission cooler, possibly an upgraded torque converter... and there's not much guarantee that this will cut it for high performance. (of course, if you drive gently from a dead stop, this won't be such a big problem)
4. The money saved against the AWD version could go to other necessary things, like a front LSD, brakes or other performance things.
March 15th, 2011 11:45 PM #410
Mga parekoy..kmusta na ang ASX nyo?...so far wala bang problem? Natapos ko na knina ang 1000km.. at tomorrow dalhin ko na sa service center for 1st PMS...ask ko lang kung mag kano pay ninyo?... di kasi ako binigyan ng voucher ng 500 discount dito sa Peak motors.... ang sabi bibigyan daw ako doon na sa counter... kyo? magkano binayaran ninyo sa discounted price?
About Ziebert.... Ok ba yung Diamond Gloss? eto raw ang wet look nila... 2 weks pa lang ang asx ko pero gusto ko ma-preserve ang kulay at glossy ng car ko... 4 hrs lang daw ang duration ng detailling at the price og Php 7,300... sa palagay ninyo worthed o may iba pang place na mas maganda?.... Thanks mga parekoy.
repair kit lang. car care nut says, for toyotas, he recommends entire assembly replacement for...
rack and pinion repair
