Page 42 of 107 FirstFirst ... 323839404142434445465292 ... LastLast
Results 821 to 840 of 2140
    umusok na naman kanina ang Taal..
    Photo looks great. Hope the folks there have cleaned up the area..
    From Source: Kanlaon Volcano last erupted in June 2016. Ash fall was experienced in several barangays in Negros Occidental after the steam-driven eruption.
    Phivolcs raises eruption alert as Kanlaon Volcano shows unrest
    Wow meron pala volcano dyan...
    Baka naman yan ang panlaban sa Covid-19, volcanic ash, baka di kaya ng virus yung sulfur nung ash? [emoji23]
    #823
    In an ambush interview after his speech in Fort Bonifacio Monday night, Duterte said he will go to affected areas in Batangas on Tuesday.
    "Kainin ko pa 'yang ashfall na 'yan. Pati 'yang Taal, ihian ko pa 'yan," he said, assuring reporters he is healthy enough to go around Batangas.
    #824
    PRIMER ON THE 22 APRIL 2020 SERIES OF EARTHQUAKES IN MABINI, BATANGAS
    DOST-PHIVOLCS recognizes the necessity of clarifying information being released by the Institute. We hope to address the concerns of the public arising from the PHIVOLCS Earthquake Information releases today, 22 April 2020 covering the Mabini, Batangas earthquakes.
    What is happening in Mabini, Batangas, Balayan Bay and vicinity?
    A series of twenty-three (23) earthquakes beneath Mabini, Batangas and adjacent areas of Balayan Bay having a magnitude range of Ms1.2- Ms3.7 has been recorded since 10:31 am today by the Philippine Seismic Network (PSN). The largest of these events occurred at 11:19 am and was felt at Intensity III in Mabini, Intensity II in Taal and Lemery and Intensity I in Agoncillo, Batangas Province.
    These earthquakes occurred within 10 kilometers south of the magmatic dike that fed the January 2020 eruption of Taal Main Crater, and could thus be volcano-tectonic earthquakes associated with post-eruptive crustal re-adjustment surrounding the magmatic dike. This interpretation is supported by current GPS monitoring of ground deformation caused by the magmatic dike in the Pansipit River Valley, which shows a general subsidence of the valley since February 2020. A more detailed understanding of the processes occurring beneath Mabini, Batangas will soon be provided by ongoing analysis of Remote Sensing data.
    What are tectonic, volcanic and volcano-tectonic earthquakes?
    •Tectonic earthquakes are produced by sudden movement along faults and plate boundaries.
    •Volcanic earthquakes produced by movement of magma or magmatic fluids or rock-fracturing beneath volcanoes.
    •Volcano-tectonic (VT) earthquakes are a type of volcanic earthquake associated with failure or breakage of rock material along faults and fractures beneath active volcanoes [see references below]. The mechanism that produces tectonic earthquakes is similar, although the root causes are different. VT earthquakes are normally triggered by excess heat and pressure from, or adjustment of the crust around, a magmatic body beneath the volcano, whereas purely tectonic earthquakes are driven by regional tectonic plate motion.
    Why are there changes in PHIVOLCS EQ Information?
    Initially, the earthquakes in Mabini, Calaca and Lemery, Batangas were reported in DOST-PHIVOLCS Earthquake Information based on the Philippine Seismic Network (PSN) data as tectonic by default due to their occurrence within the locality of the 8 April 2017 M6.0 Mabini Earthquake. Upon review, however, of data from the Taal Volcano Network (TVN), these events were recognized as likely volcano-tectonic or VT earthquakes, relocated in the Mabini area and revised as “volcanic” in updated DOST-PHIVOLCS Earthquake Information. The magnitudes of these earthquakes were also revised to ML or local magnitude calculated by the TVN, which typically differ than the customary MS or surface magnitude calculated by the PSN, and reported as ML2.9- ML4.6 in the updated Earthquake Information.
    DOST-PHIVOLCS acknowledges the need to clarify information regarding the Mabini earthquakes today and the necessity of distinguishing volcano-tectonic earthquakes from other volcanic earthquakes of direct magmatic causes. In view thereof, VT earthquakes shall henceforth be explicitly classified as “Volcano-tectonic” rather than just “Volcanic” in order to avoid confusion amongst the public. Earthquakes classified as volcano-tectonic should not be interpreted by default as being related to renewal of magmatic unrest; rather, day-to-day seismic activity in Taal Volcano is explained in the Taal Volcano Bulletins issued daily at 8:00 am. Issuances of Earthquake Information reporting VT earthquakes shall continue so that populations that have been affected by these events can be provided information especially when ground shaking has been felt.
    References:
    [1] Zobin, V., 2003. Introduction to Volcanic Seismology First Edition. Developments in Volcanology, Volume 6. Elsevier Science.
    [2] Chouet, B.A., Matoza, R.S., 2013. A multi-decadal view of seismic methods for detecting precursors of magma movement and eruption. J. Volcanol. Geotherm. Res. 252, 108–175.
    [3] McNutt, S.R., 2005. Volcanic seismology. Annu. Rev. Earth Planet. Sci. 33, 461–491.
    Radyo LipenioLike Page
    2h ·
    JUST IN | Kasalukuyang naglalabas ng puting usok ang bulkang Taal ngayong umaga August 18, 2020
    Sa ngayon ay nananatiling nasa alert level 1 ang bulkan
    Babagsak talaga presyo lote sa tagaytay, cavite batangas
    #826
    "the best time to buy, is when someone wants to sell."
    #827
    2h ·
    Just clouds
    Twitter
    Jul 2004
    #828
    Nothing to worry about for now
    Our area was affected by the Taal eruption and I have been monitoring the volcanic quakes since it hit a high of 39 last 23 April 2020
    Since then, the number of volcanic quakes are going down down down, in single digits and even two instances of 0 volcanic quakes in August.
    Then again, no one can control mother nature.
    #829
    It's been exactly one year since the "little beast" erupted.
    Jul 2004
    #830
    Happy Anniversary Taal Volcano Eruption!
    Some data to chew on as we remember this day:
    105 - total number of straight days to date of SINGLE digit volcanic quakes (period from 30 Sep 2020 - 12 Jan 2021)
    27 - total number of ZERO volcanic quakes during the above period
    25 - total number of straight days with 0-1 volcanic quakes during the above period
    1.9 - average number of volcanic quakes per day during the above period
    Alert Level 1 (Abnormal) remains but getting better.
    Hopefully, if the trend continues, Taal will be classified NORMAL in the next month or so
    #831
    Merton ba sa inyong kinalawang sasakya o may nadorang pines a Dahl sa eruption?
    #832
    yung friend ko from batangas bro wala problema yun old altis 2009, 2018 hilux and fortuner wala din problema re:rusting
    windshield lang talaga may light scratches
    #833
    Siguro ginamit nya wiper para sa ashfall.
    #834
    yup mag asawa na di masyado maalam sa auto bro
    palit lang ng palit every 5 years
    #835
    I learned a lot of things after the Mt. Pinatubo eruption.
    1. Water & volcanic ash is a very destructive combination. Sulfur in it turns into sulfuric acid. When wet, it holds water, enough to magnify it weight. After it dries, it’s like cement.
    2. Ash, after falling, is so light that it’s easy to blow off
    3. Ash is so abrasive. Many, caught unaware, used their wipers & washer, permanently scratching their windshields. Some naman used wet rags to wipe the rust off. Even just drawing down windows scratched the glass.
    As a precaution also, I changed the air filter.
    Jul 2004
    #836
    Bad news: TAAL VOLCANO BULLETIN: 7 FEBRUARY 221 8: A.M.
    This ends the straight 130 day run of single digit volcanic quakes dating back to 30 September 2020.
    The 41 volcanic quakes registered in the last 24-hour period is more than the 11 quakes on 29 September 2020 and highest since the 39 quakes registered on 23 April 2020.
    Alert Level 1 (Abnormal) remains. Hopefully this is just a fluke, an isolated incident.
    #837
    Jul 2004
    #838
    Taal's 98 tremors in the past 24 hours is the highest since 21 April 2020 and since I started monitoring this.
    Hope it calms down.
    Really praying it calms down.
    Parang binalik lang yung last time... pumotuk si taal tapos pandemic na... ngayon anjan nanaman si taal tapos pa akyat na naman ang cases...
    Jul 2004
    #840
    Taal registers 69 tremors in the past 24 hours: TAAL VOLCANO BULLETIN 17 February 221 8: A.M.
Taal Eruption 2020
