Results 911 to 920 of 2105
- 5,172
March 4th, 2021 10:14 AM #912T.V. is still erratic so there's no way people should let their guard down.
March 4th, 2021 10:30 AM #913
- 5,172
March 6th, 2021 09:17 AM #916
Taal still restless with 16 volcanic quakes: TAAL VOLCANO BULLETIN: 6 March 221 8: A.M.
And the volcanic quakes of the other volcanoes being monitored in the past 24-hour period:
Mayon - 0
Pinatubo - 6
Kanlaon - 9Last edited by 111prez; March 6th, 2021 at 09:20 AM.
March 7th, 2021 09:08 AM #917
TAAL VOLCANO BULLETIN 7 March 221 8: A.M.
Volcanic earthquakes are down by an average of 2 per day in the past 3 days.
However, tremor episodes continue to increase but still way below the triple digits recorded last 4 March.
Overall, while there is still no preceptible trend towards normal status, Taal seems to be calming down.
- 54,301
March 7th, 2021 09:16 AM #918
March 7th, 2021 10:21 AM #919
Godd question.
I am no volcanologist or geologist but I found these:
Volcanic Earthquake - an overview | ScienceDirect Topics
Volcanic Earthquakes
From the latter article:
"Earthquakes produced by stress changes in solid rock due to the injection or withdrawal of magma (molton rock) are called volcano-tectonic earthquakes (Chouet, 1993). These earthquakes can cause land to subside and can produce large ground cracks. These earthquakes can occur as rock is moving to fill in spaces where magma is no longer present. Volcano-tectonic earthquakes don't indicate that the volcano will be erupting but can occur at anytime."
"The second category of volcanic earthquakes are long period earthquakes which are produced by the injection of magma into surrounding rock. These earthquakes are a result of pressure changes during the unsteady transport of the magma. When magma injection is sustained a lot of earthquakes are produced (Chouet, 1993). This type of activity indicates that a volcano is about to erupt. Scientists use seismographs to record the signal from these earthquakes. This signal is known as volcanic tremor."
Phivolcs only started reporting both volcanic earthquakes and tremor episodes in its bulletin last 14 February.
Before that, they reported only on volcanic earthquakes.
From my layman's point of view, having one or the other or both are causes for concern.
Hopefully, the numbers will go down until it is back to normal, meaning 0 for both just like Bulusan.
- Oct 2006
- 6,302
March 7th, 2021 10:32 AM #920It'll be long while till it goes back to normal status. Especially as the tremors are getting longer in duration. Its not just the quantity of earthquakes but the quality (type, magnitude, duration). Mayon last erupted in 2018 and its still abnormal till now. I remember Taal at Alert Level 1 in 2005 and it lasted for almost 10 years. But again as long as you are not on the island, you should be safe.
A tremor episode is a volcanic earthquake. Its just a distinct type of volcanic earthquake. Most volcanic earthquakes are relatively short-lived, less than 5 second duration associated with breaking rocks or a popping gas bubble or explosion. Tremor episodes however are long duration, lasting from a minute to sometimes hours., can be due to popping of many gas bubbles, boiling water at depth and causing a vibration in a conduit.
Exactly! It’s an exciting time — more affordable and practical EVs are definitely on the way.
Audi will no longer develop new...
