Results 41 to 50 of 2105
January 12th, 2020 09:55 PM #41
From a Viber thread...
zero viz nuvali area.avoid CALAXand SLEX at least from binan to sta rosa.hirap mag drive basta basta na lang may humihinto as daan kahit Expressway lalo yung walang tubig ang windshield wiper.better uf you dont drive coming to or from these areas.keep safe everyone.
- Jan 2008
- 4,726
January 12th, 2020 10:05 PM #43
- Dec 2019
- 97
January 12th, 2020 10:05 PM #44To our dear Toyota customers:
Due to the recent ashfall from Taal Volcano, please be advised of the following immediate measures to protect your vehicle/s :
1. Please wash your vehicles with pressurized water to remove ash from the vehicle's body, but please do not wipe the vehicle while spraying water to avoid scratches on the vehicle's body
2. Please repeat if vehicle continues to be covered with ashfall
3. If engine room is affected, please bring your vehicle to your nearest Toyota dealer for proper engine cleaning.
Please also protect yourself from the ashfall while cleaning your vehicle by wearing protective gear like raincoat and mask.
Please contact our dealer if you have questions.
Thank you
- Dec 2019
- 97
January 12th, 2020 10:07 PM #45Don't use aircon daw
Due to the recent ongoing ashfall from Taal Volcano please be advised of the following measures to protect your airconditioning system:
If you experience heavy ash fall, kindly refrain from using your Split type airconditioner and window type airconditioners.
Continued use with heavy ashfall will result in the clogging of the outdoor condenser coil, which in turn will cause overheating of the compressor and overall airconditioning system.
Should you really need to use your Air Conditioning units, kindly be advised to wait until the ashfall decreases, then clean the area where your condenser is located before you resume air conditioner operation.
January 12th, 2020 10:14 PM #46
Volcanic ash is detrimental to jet engines, no flights to airports will be possible
Madedelay ang deliveries from shopee & lazada
Sent from my SM-A520W using TapatalkLast edited by kisshmet; January 12th, 2020 at 10:20 PM.
January 12th, 2020 10:17 PM #47
January 12th, 2020 10:28 PM #48
- 54,290
January 12th, 2020 10:30 PM #49
Interesting thread—really important to consider the broader impact of the National ID Law beyond...
National ID Law
