Page 1 of 36 1234511 ... LastLast
Results 1 to 20 of 2145
    From a Viber thread...
    zero viz nuvali area.avoid CALAXand SLEX at least from binan to sta rosa.hirap mag drive basta basta na lang may humihinto as daan kahit Expressway lalo yung walang tubig ang windshield wiper.better uf you dont drive coming to or from these areas.keep safe everyone.
    Oct 2017
    Hello from QC. My true qc.
    Nasa PH ka pala?
    Oct 2017
    Nasa PH ka pala?
    Yes sir! flight out tomorrow dapat pero by the looks of it, my vacation will be extended.
    Dec 2019
    To our dear Toyota customers:
    Due to the recent ashfall from Taal Volcano, please be advised of the following immediate measures to protect your vehicle/s :
    1. Please wash your vehicles with pressurized water to remove ash from the vehicle's body, but please do not wipe the vehicle while spraying water to avoid scratches on the vehicle's body
    2. Please repeat if vehicle continues to be covered with ashfall
    3. If engine room is affected, please bring your vehicle to your nearest Toyota dealer for proper engine cleaning.
    Please also protect yourself from the ashfall while cleaning your vehicle by wearing protective gear like raincoat and mask.
    Please contact our dealer if you have questions.
    Thank you
    Dec 2019
    Don't use aircon daw
    Due to the recent ongoing ashfall from Taal Volcano please be advised of the following measures to protect your airconditioning system:
    If you experience heavy ash fall, kindly refrain from using your Split type airconditioner and window type airconditioners.
    Continued use with heavy ashfall will result in the clogging of the outdoor condenser coil, which in turn will cause overheating of the compressor and overall airconditioning system.
    Should you really need to use your Air Conditioning units, kindly be advised to wait until the ashfall decreases, then clean the area where your condenser is located before you resume air conditioner operation.
    Oct 2007
    Huhuhu pano na flight ko sa 14 pabalik ng pinas, hope the eruption will settle down by tomorrow.
    maybe they can land in clark..?
    Mar 2017
    Forecast is for ashfall to reach as far as Tarlac. Damay ang Clark.
    Which one is the real Taal Volcano?[emoji12]img-fed82f30ded198dc1c626ba857e05859-v.jpg
    Oct 2017
    Sabi nga daw "taal lake is the caldera", meaning that whole thing is the volcano.
    And since Taal volcano is a complex volcano, malamang totoo ngang caldera yang lahat ng nakikita natin. yikes.
    Jun 2015
    Binintiang Malaki daw ito:
    tama si carpy.
    that entire body of water known as taal lake, is the volcano's mouth.
    so now that we know... we may now get real scared.
    tama si carpy.
    God help us. [emoji12]
    on another note,
    mount makiling is also a volcano.
    on another note,
    With no historically recorded eruptions. Hope it doesn't do a Pinatubo in the future.
    Aside from Makiling, there is also Arayat in Pampanga.
    i believe it's listed under "dormant" volcano... just like pinatubo was, before it woke up.
Taal Eruption 2020
