brain mafia... afaik pwedeng lagyan ng ats 5kva.... meron kami ats pwede ito gamitin up to 200 amperes.. 30k lang...
Brown out ngayon dito sa manila area. Dry run na ba talaga ito?
1MW wow hindi lang palasyo! Barangay na yan. Aside from diesel you have to change the oil. Baka 200 liter or more of oil yan. Plus multiple fuel and oil filters. Plus the noise. You need a 40 FT container van for the generator. Tapos most likely specs nyan ay 480 volts 3 phase. You will need a transformer to step in down to 220 volts.
kasing mahal ng ats mo genset pre. saan ka ba nagwowork? baka magkakilala na tayo. hahahah. matagl ako sa federal land, hawak ko residential at commercial building nila, one of the few is GT Tower, property manager nila ako dati. now nasa cvg na ako.
1Mw nga pre or 1250kVa, dahil may chiller sa bahay si amo.
boss 2010, pa na issue yan, at inaantay din namin sa industriyang pinagtatrabahuan ko. pero i am sure that it would be earlier due to improved construction procedure at masyadong madaming residential and commercial development ngayon.
if i am not mistaken, because of epira of 2001, nagamit na ng gobyerno ang mga IPP dahil sa WESm market or nakakasali na ito as source ng NGCP.
kaya IMHO at AFAIK it will be earlier like 2014 late or early 2015.
Pag 1600A up advisable ba na air circuit breaker type ang ats mo at hindi ung switch over contacts lang?
Ang taas ng demand factor natin sa kuryente ngayon summer sir ayun bumigay na.
*glennmanikis :: Ako rin sana glenn. Yung kaya 1.5hp AC, isang TV, roomlight, isang ref at internet. Pa-PM nalang. Yung tahimik lang din.
heard on the news today, may initial analysis sila na ang cause ng 50% black sa luzon is may nagsiga sa ilalim ng transmission line. im like WTF!!. ganon ka fragile electricity natin? isang siga lang 50% black out na sa buong luzon?
Not as bad as the power crisis in Pakistan.
Don't wear socks, hot Pakistanis told amid power crisis | Reuters
Islamabad | Mon May 20, 2013 4:19pm IST
(Reuters) - Pakistan has told civil servants not to wear socks as the country turns off air-conditioners amid a chronic power crisis and soaring temperatures.
The government has turned off all air-conditioning in its offices as the country endures blackouts of up to 20 hours a day in some places.
"There shall be no more use of air-conditioners in public offices till such time that substantial improvement in the energy situation takes place," a cabinet directive said.
As part of a new dress code, moccasins or sandals must be worn without socks.
The power shortages have sparked violent protests and crippled key industries, costing hundreds of thousands of jobs in a country already beset by high unemployment, a failing economy, widespread poverty and a Taliban insurgency.
