Page 2 of 2 FirstFirst 12
Results 21 to 38 of 38
    That device is a normally open switch terminal which connects the load to the 220AC line once the switch is activated.
    All you have to do is connect the load to the switch in SERIES.
    Sent from my GT-P3110 using Tsikot Forums mobile app
    How?
    #22
    Saan i-tapped yun 2 wires na lumabas sa wall?
    did it come with an instruction sheet?
    Sep 2004
    #23
    Quote Originally Posted by AllenR View Post
    I think it should be like this
    Or ganire, found it online
    Sent from my SM-G930F using Tapatalk
    Jun 2015
    #24
    That diagram for the "switch" is wrong.
    Sent from my ASUS_T00J using Tapatalk
    Jul 2017
    #25
    correct no need for 220v power supply on the switch side.
    So paano nga?
    Quote Originally Posted by L1quid View Post
    Paano gagawin doon sa type A wiring? Parang meron jumper pa?
    Dec 2009
    #28
    How?
    AC ba ang power supply ng load mo?
    If AC ang supply ng load mo at AC din ang supply ng device mo then you tap the 220AC to the AC line of the gadget
    Connect the middle terminals of the gadget
    The leftmost terminal of the gadget goes to one of the terminal of the load and the other terminal of the load goes to the rightmost terminal of the gadget
    Switch ng ceiling light gagamitin not in appliances.
    #30
    i think i get it.
    the two right terminals are connected to your power supply. either to the house socket (220V), or to a small power supply (12V). if 12V, be mindful of the polarity.
    the two left terminals are now your manual switch terminals' new connections. connect them to the two wires going to that manual switch, and discard the switch. or, you can connect in series to the switch, so's you have both remote and manual options.
    Dec 2009
    #31
    Disconnect (cut one of the AC line from the ceiling switch) first one of the terminal of the light ceiling switch to from the AC line then tap it to the leftmost terminal of your gadget. That will leave one of the AC line hanging so u better cover that line covered with electrical tape
    Note if youre not an electrician, dont attempt to do it this way. Ditch the ceiling switch
    Connect the middle terminals of the gadget together
    Tap one of the 220AC line to the left AC line of the gadget then tap the other 220AC line to the right AC line of the gadget
    Now that makes it 2 switch in series before the load gets attached to the 220AC line
    Jan 2009
    #32
    I think ang problem is, if understood the TS correctly, ay walang 'partner' na 220V sa loob ng existing light switch.
    Yung "switch" terminals ng timer should replace the existing switch. However, in order for the timer to work, it also needs to receive power from a 220V source. Kung wala syang makuhang 220V source sa loob ng switch junction box, he will likely need an electrician to lay the wire for him.
    Otherwise, medyo ghetto kalalabasan kung latagan nya ng wires papunta sa 220V outlet.... pangit na tignan kung nakalitaw yung wires sa wall.
    Dec 2009
    #33
    ^that should be the ideal thing to do, replace the switch for the light ceiling with the timer switch but he did clarify that the load is the switch..so that makes it a redundant switch
    The load should be the light with timer switch replacing the wall mount switched where the light was initially connected from
    Jan 2009
    #34
    Proper method:
    Ghetto method:
    Excuse the crude sketch.
    Typically, your home would've been wired as such (BROWN wires in the sketch). In order to use the timer (assuming it requires 220V AC to operate, NOT 12V DC), additional wirings are needed (PINK wires) to connect to a 220V AC source.
    Dec 2009
    #35
    Shadow do you intend to use the existing wall mount switch of the ceiling light as a bypass switch to the timer switch?
    No. But since it's too complicated, I think it's easier to teach na lang yun maid to turn off and on the lights sa time na gusto ko. [emoji23]
    Jun 2008
    #37
    good decision or hire ng marunong na electrician madali lang sa kanila yan. mahirap ng magmarunong pagdating sa kuryente. safety first.
    Sent from my SM-G950F using Tsikot Forums mobile app
    Jun 2012
    #38
    Install a motion sensor with IR detector.
How do you wire a wall light switch to this timer?
