Do you mean papalitan ko roof ko just to have the insulation replaced?
The insulation is riveted between the purlins and the metal roof. A contractor can remove the roof, install the roof insulation, and reinstall the roof. We typically use 12mm PE foam with aluminum foil on both sides.
I misunderstood that you wanted to change the entire roof
