Results 151 to 160 of 756
June 4th, 2019 09:19 PM #151
- Nov 2019
- 1
January 30th, 2020 07:46 AM #153
- Oct 2014
- 1,232
January 30th, 2020 07:58 AM #154Nakapasok na rin kasi halos ng 75mm yung base plate mo from the outer edge of the tread. Hindi ko alam ang anu preparation ginawa nyo. Pero mas matibay sana kung naglagay kayo ng provision for hinang. Hindi rin matibay syado expansion bolt or using chemical anchors.
Pwede rin pagawa ka ng 3" balusters para hindi syadong malapad. May I ask, anu ba lapad ng hagdan mo, bawas mo na ang balusters width?
Sent from my vivo 1811 using Tapatalk
January 30th, 2020 08:48 AM #155
Pinatong ko lang yan sir for pic purposes, 1 meter lang kasi ang stair width, contractor error, kasi sabi ko 120 cm, ang sabi ng installer, maglalagay daw sya base plate sa side tapos patong yan, pero parang masagwa kung ganun
No preparation done sir, bakal at cemento lang yan
- Oct 2014
- 1,232
January 30th, 2020 09:22 AM #156Hindi ako sigurado, pero min clear width ata ng stairs is 120cm as per building code for commercial building. Ang mangyari sayo sir, 90cm na lang clear width mo, if tama estimate ko na 10cm baluster mo.
My suggestion, gawan nyo paraan na may mapatungan lang mismo yung paa ng baluster, gawa kayo support which thicken out sa stringer, drill sa side put rebars then, buhusan mo ng structural grout.
Or pwede rin sabi ng installer na maglagay, sila ng base plate na mag clip sa side ng hagdan, conceal it, using wood/plastic moulding. Try mo rin ask if may makunan sila ng aluminum composite panel(ACP), pwede rin gamitin pangtago. Paint afterwards same color (or anu kulay gusto mo) as your stairs, you're done.
January 30th, 2020 11:58 AM #158
January 30th, 2020 12:59 PM #159
Thanks Sir Travs, I also did some googling and found a lot good side mount options. I guess my true problem lies in the fact that I am currently limited to 1 provider to whom I already have a good experience with. I asked also if he can find good side mount options. This part of construction is tricky because you need to pay 50% upfront and there are many sad stories of non delivery or non completion.
January 30th, 2020 01:06 PM #160
Traffic!
