Page 43 of 46 FirstFirst ... 333940414243444546 LastLast
Results 841 to 860 of 908
    Jan 2009
    #841
    Check out PULSAR 12000 WATT PORTABLE DUAL FUEL PROPANE/GAS GENERATOR ELECTRIC START for ₱8,000. Get it on Shopee now! https://shopee.ph/product/292408789/...8-1629266603.9
    Unbelievably low priced genset!
    "Buy 2 get 1 free"
    Yeah, those can't be real.
    Mar 2005
    #842
    If you're OK with refurb then you could scout along Evangelista Quiapo. There are Robin,Yanmar and Kubota Diesels surely they have parts.
    If you're OK with China copycats there is this Briggs & Stratton called Promax, try calling this shop - Trioidad Trading, #1643-A Soler St., Sta Cruz, Manila TL# 5310-0401 look for Boyet 09564926715. Everything else China i guess is disposable, goodluck finding spare parts.
    Honestly IMO if requirement is just for emergency backup then i'd get the cheapest brand new, you just have to maintain the jets of the carb make sure it doesn't clog when not in use.
    Sir how often need linisin yung jets? Bought a brand new chinese brand na gas generator and di ko pa nagagamit. Pina paandar ko lang once a month.
    Quote Originally Posted by jmpet626 View Post
    Ok na yan ginagawa mo, ako nga kung maalala ko lang start saka ko napapaandar hinde religiously na every month.
    Ayan since nabasa ko dito paandarin ko mamaya or bukas na lang. [emoji23]
    Dec 2019
    #844
    Sa ace yan? Co ban kiat yata supplier niyang, China din lang yan sa Evangelista ka na lang bumili. Rebranded din lang yan. Sa sobrwng mura ng china made kung masira na bumili na lang ng bago.
    Feb 2014
    #846
    i drain all fuel. then i open the bowl and blow out all traces. if you store it dry then it'll start up reliably the next time you need it which could be years from now
    #847
    In my experience with gasoline gensets, its better to leave the fuel than drain the reservoir. Those jets gets clogged more easily when air interacts the metal turning into surface corrosion. If fuel is still in the carb, bottom parts are insulated from air thus there's less tendency to corrode. Just like any engines, warm it up every month or week (if possible) to lubricate/insulate the internal parts. If neglected for long period of time, drain the stale fuel from the reservoir, replace gear oil, clean air filter before trying to start. Check readiness of genset if power outage is anticipated like Typhoons/ rotational brownouts. I also stock spare spark plugs and fuel hose because they are the consumable parts that usually break.
    Feb 2014
    #848
    well there's 2 stroke oil covering the parts so i didn't get corrosion. i got a generator like 10yrs ago i only got to use it last year haha. basically i just did what i outlined above and left it inside the box for like 7 years. it started up instantly
    Dec 2019
    #849
    Yep display ito sa ace last time i went there..
    Sent from my SM-N970F using Tsikot Forums mobile app
    Jul 2013
    #850
    I have the opposite experience. I use to leave fuel in my small genset. Carb got blocked in some tiny holes. RPM was fluctuating wildly.
    Now, when it is time to turn off the genset, I just set the petcock valve to OFF and let the engine die of fuel starvation.
    Jan 2009
    #851
    Can anyone recommend a reputable store in Raon/Evangelista?
    Saan pa ba maraming portable gensets, or is this it?
    #852
    specifications? capacity?
    maraming light duty sa mall.
    Dec 2017
    #853
    I don't know if this is expensive or not but the one I saw in harbor Point is more than 30,000 Pesos for a capacity of 4.5kVA.
    Diesel? Pag gasoline mahal yan
    Dec 2017
    #855
    I didn't check as I was only passing by but I'm also interested to buy one. I want to run 2 submersible pumps rated at 1/2 hp each and A/C at 2.5 hp. What's the recommended kVA rating that I should get?
    Sorry, I'm a bit "lazy" to compute. [emoji3]
    10 KVA.
    Dec 2017
    #857
    10 KVA.
    I thought I made a mistake!!! I kept on saying that I think it's too much. Thank you for confirming.
    Any idea where to buy a cheap one? I'm contemplating for diesel, silent type. It might be too expensive for something I won't be using regularly.
    Any idea which one is easier to maintain, gasoline or diesel?
    Si *uls nagbebenta ng genset.
    Pero ang generator king si Glenn manikis
    #859
    Ano'ng too expensive, bro.?
    The first time you had a need to use it and it worked as you expected,- fully paid na iyan!
    #860
    Quote Originally Posted by Lew_Alcindor View Post
    I had the same experience years ago
    And i am doing the same thing bro.
Generator sets
