Page 42 of 46 FirstFirst ... 32383940414243444546 LastLast
Results 821 to 840 of 908
    [emoji1787][emoji1787][emoji1787]
    Kung mag gegenerator, sa ref, efan at lights ang priority for those? Yan ba set up sa house nyo din?
    Yes. Saka isang A/C na 1 HP. Pero more often than not, hinde na rin mag A/C pero at least kung kailangan pwede gamitin.
    Nakikita ko yan sa mga askal na pinapatay... [emoji30]
    Kaya di advisable ang generator for aircondition purposes... [emoji1787][emoji1787][emoji1787][emoji3577][emoji3577][emoji3577]
    Pwede naman basta malayo yun genset saka sa open, kung totoo yun sabi ni baludoy, sobrangnl irresponsible naman doon nilagay sa ilalim ng A/C yun genset.
    Meron code yan eh kung ilan meters dapat layo sa mga windows gayahin mo na lang yun code sa America.
    Jan 2016
    #823
    Naku malaki yan! 1 hp is 750W diba? So multiply mo ng 9 since 3 units x3 starting niyan. Almost 7kva na sa 3 AC pa lang
    Plus mo pa wattage nun 2 fridge x3 edin starting niyan each
    Stand fan? 100-150*? X3 mo ba rin each niyan
    LED TV so wala na siguro starting yan Tinganan mo kung ilan watts na lang each
    Lights minimal na rin mga yan.
    Kwnetahin mo kung ilan KVA na kailangan mo more or less pang mall na siguro dapat bilhin mo. [emoji23]
    Kwentahin mo lang ang total kw required for all plus x3 sa pinakamalaking wattage, tutal pwede mo naman pa andarin yan one at a time, just make sure meron ka pang x3 dun sa last aircon na matitira.
    Mas maganda na over-over. Mamaya mag automatic sabay sabay yun A/C [emoji23] well at least for noninverter.
    Dec 2009
    #825
    ^the generator should always be more than capable to provide the energy requirements of the load (home appliances)
    Also the wire that will connect the generator to the load should be more than capable to handle the current required..otherwise, you could burn the household
    Sent from my SM-G532G using Tapatalk
    Meron na ba gumawa na sa g3nset 12v port nag jump start ng kotse? Pwede ba yun?
    You will need proper gauged cables. I think my jumper cables are good but it got warm. Whats the max current output of your 12 dc power supply?
    Id get one of these...
    Dec 2009
    #828
    Its possible but theres a risk of an overload. Overload is the state when the load draws more current than what the generator can provide. The starter circuit of the vehicle can draw a lot of current to start an engine thats why jumper cables are thick
    If your generator is not equipped with an overload protection circuit (fuse) then you could risk ruining the rectifier circuit (diode) of the generator
    Considering not all generators have the same capacity. Its dangerous to assume that if it worked for others..it will also work with your generator..it all depends on the capacity of the generator
    I think the fuse is 10-20a. It'll blow safely lmao.
    #830
    we used to have a car battery charger with engine start capability. plugging it into our house wall socket, it would start our old skul cars with weak battery. there are local ads for such start-capable car battery chargers.
    puede rin, i suppose, i-plug sa genset. but you have to have a genset that can safely supply the hi wattage, i.e., 1500-2000 watts or so.
    but i am old skul.
    my concern is the modern car's cpu.
    can it function using interrupted direct current?
    because if not, you will have to look for a circuit that offers continuous or smoother direct current.
    May 2019
    #831
    Quote Originally Posted by Lew_Alcindor View Post
    Matagal ko na nakikita sa mall yang Navigator. Mukang okay naman. Yung price mukang reasonable naman.
    Yung akin ay Yamada brand (1000W).
    Okay naman siya except for baradong carburetor pag matagal hindi nagagamit. In this case, dapat drain lagi gas sa tank at karburador bago itago.
    Thank you Sir Lew sa feedback, malaking tulong.
    Parehas lang lahat ng generator. Walang special,
    Once in a blue moon lang ggagamitin. I always advice get the highest KVA generic china genset you can afford para hinde na kailanga mag upgrade.
    Pag nasira which is hibde ko alam kung paano masisira. Eh bumili na lang ng bago ulit.
    Kung mga subcon ng Maynilad yun genset na gamit nila sa Jack hammer eh napuputikan, nababasa pero buhay pa rin.
    Thank you dito Sir Shadow.. Pati dun sa computation.
    Buti na lang nag tanong ng additional si Ray pati na din dun sa warning ni Sir Baludoy.. And sa iba pa.. Binigay ko pa lahat ng info sa kanya.. Iba pa din yung meron input from users.
    For reference only just in case...
    How Many Watts Do Appliances Use? | Prime Reviews
    Jan 2009
    #833
    I need a recommendation for a genset in the 5,000 to 7,000W range. I don't mind if it's cheap or generic, as long as it has local support for parts and aftersales service.
    #834
    Jan 2009
    #835
    Too expensive. I know it's a Honda but for about 15k less than their listed price, I could get an 8kVA Lotus silent-type Diesel. Now, that's IF I have that money.
    No, something a lot cheaper... think whereabouts of 25-30k.
    Dec 2017
    #836
    I hope you don't mind posting the link for that 8kVA.
    #837
    If you're OK with refurb then you could scout along Evangelista Quiapo. There are Robin,Yanmar and Kubota Diesels surely they have parts.
    If you're OK with China copycats there is this Briggs & Stratton called Promax, try calling this shop - Trioidad Trading, #1643-A Soler St., Sta Cruz, Manila TL# 5310-0401 look for Boyet 09564926715. Everything else China i guess is disposable, goodluck finding spare parts.
    Honestly IMO if requirement is just for emergency backup then i'd get the cheapest brand new, you just have to maintain the jets of the carb make sure it doesn't clog when not in use.
    Jan 2009
    #838
    Now that I've thought about it, this may not be the actual price. I see a lot of big-ticket items that are listed with an unrealistically low price. You will need to investigate further.
    LOTUS 8KVA Silent Diesel Generator Set, Electric Start, Air-cooled, Single Phase (DL8EX) | Lazada PH
    Yeah, it's for emergencies only. With our utility power pretty stable as of late, there's not much demand for them so the prices are relatively low now. Best time buy one.
    I am actually looking at the off-branded ones, Chinese or otherwise. Oshima, Blackstone, Anmax, Powerhouse, etc. With the kids' online classes and I'm still WFH, this could come in handy when needed.
    Ok na yan. I had elemax before 3kva kamahal mahal ganun din minsan lang Magamit pinalitan ko na ng 5kva na China few years back, buhay pa rin naman hangang ngayon.
    Brwnd new China made ok na yan. Wala naman masisira eh, kung yun mga gamit nga third party contractor ng mga utilities for their jack hammer super laspag ng mga genset nila nababasa pa tapos puro putik buhay pa rin.
    Dec 2017
    #840
    Check out PULSAR 12000 WATT PORTABLE DUAL FUEL PROPANE/GAS GENERATOR ELECTRIC START for ₱8,000. Get it on Shopee now! https://shopee.ph/product/292408789/...8-1629266603.9
    Unbelievably low priced genset!
Generator sets
