Page 72 of 91 FirstFirst ... 226268697071727374757682 ... LastLast
Results 711 to 720 of 908
    Sep 2013
    #711
    ^^ kapag ang supply ng AC current ay fluctuating (like meralco) kailangan ng UPS para laging constant ang current supply nito pero kung ang appliances naman ay auto volt from 110v to 220v no need na
    #712
    Quote Originally Posted by jasonub View Post
    Grabe laki ng capacity.
    On a similar note, pwede ba gumamit ng portable generator power sa mga inverter ref and air-conditioning units? Sensitive ba eto?
    I know tv and computers are a no no unless you have a true sine wave inverter generator. Unless you have a UPS backup
    The gensets sold here have voltage regulators but i doubt if its clean sine wave generators since portable lang and less than 40t pesos.
    Any inputs will be great since this month na simula ang brown outs of the aquino government. Like mother like son hehe
    Bro,- Puwedeng gumamit ng conventional/portable gen sets for inverter type refs and AC units.... I am doing that.
    Which reminds me to fire up my genset this weekend....
    25.8K:shazam:
    #713
    mga ka tsikot..
    we have on stocks large capacity gensets.. 938kva 1000kva 1250kva, 1500kva, 2500kva.. on stock yan sir..
    pati pang power plants meron kami.. pati biogas powered...
    Wow! That can power up a small barangay... Like a million pesos for the entry level units, bro?....
    25.8K:shazam:
    #714
    Ang mahal din ng large capacity UPS bro, hehe. Kaya balak namin tutal daytime lang naman ang brownout according to Sec. Petilla, mag-mall na lang or hotel. To be fair di naman kasalanan ng current admin yung shortfall sa power. It takes a long time to put up power plants. Si GMA ang hindi naghanda ng future capacity. Ok din lang ako sa ILP, yung mga komunistang nagpipicket lagi sa Mendiola na lang ang magtiis sa init at dilim kung gusto nila.
    Jul 2013
    #715
    uls
    post mo na available units mo.
    a friend of mine is looking for one.
    uls
    Sep 2009
    #716
    Quote Originally Posted by Lew_Alcindor View Post
    uls
    uls
    Ako rin, looking for one for personal use. Between 6kVA to 10 kVA.
    uls
    uls
    Mar 2005
    #717
    salamat mga kapatid.
    Got mine sa miguel motor electrical supply. 713 evangelista for commandant quiapo manila. 313 5899 381 82 44 5.5 kw gen set diesel. kala ko 6 kw. 35,000 last 7/28/14 2 years service warranty siya
    #718
    Fired/Warmed up our genset last weekend...
    Running A-OK.....
    25.9K:branch:
    Sep 2009
    #719
    DIESEL OR GASOLINE FED GENERATOR
    1. Can you pls share your opinion here what would be the pros and cons for each, aside from cost difference and noise level. Noise level is not an issue for me, and cost is a matter of upfront CAPEX (in favor of gasoline) vs regular fuel OPEX (in favor of diesel).
    2. Also, I can see some ads saying inverter type and non-inverter type generators - what does each mean?
    3. I need to provide for all lights, 2 LED TVS, 1 ref, 1 desktop PC and 2 electric fans. Is 6kw or 6 kVA more than enough?
    4. What is the difference between kW rating and kVA rating?
    5. What is the significance of single phase vs triple phase? What is suitable for home use?
    6. And what is the significance of power factor, is it relevant for home use?
    7. Can you recommend a good shop or seller for generator for home use?
    Thanks for those who can help me understand.
    Jul 2013
    #720
    Quote Originally Posted by ano727 View Post
    Not to be rude, but you are asking a lot in one post. I suggest you google first, and ask here what you do not understand fro your own research.
    I am willing to answer some of your questions based on my own googling but first, how much is your budget?
    If I am correct, diesel gensets are more expensive than gasoline gensets. You can find diesel genset only from units with output of 3000watts up. Lower output gensets are gasoline fed.
    Inverter- more expensive but also more efficient than common gensets.
    6kva genset is more than enough for the specified appliances.
    kw vs kva? Yan ang ndi ko alam. Hahaha
    Sent from my GT-N5100 using Tapatalk 2
Generator sets
