Page 51 of 91 FirstFirst ... 4147484950515253545561 ... LastLast
Results 501 to 510 of 908
    #501
    How about those 1 and 2 kva inverter generators? Are they any good? Ryobi?
    good brand kaso for occassional use of pwer tools yan, i meant na sa ibang bansa kasi pag gumagawa sila ng bahay di pa nakatap sa power line kaya nagdadala sila ng genereator for thier tools
    15 k for a ryobi 1kv i would rather buy a gasoline gen which cost only 5 k- is it worth the extra 10 k, heck no if you ask me
    #502
    ^^^ i think the selling point of the inverters is that they are safe for electronics, like led tv. Meron kasi 2nd hand na ryobi 2000 selling for 16k.
    ok, if you suggest buying a cheaper alternative, di ba maingay? Or can we install a better muffler? I need at least 1500 watts rated as i will be running the fridge on it plus lights and fans.
    #503
    They are all safe in electronics. most electronics power supplies have wide voltage and phase plus large filters.
    Good thing with conventional generators is that they are easy to maintain plus lots of interchangeable parts. Kung inverter baka walang support, kung masira at walang pyesa matagal-tagal ang downtime mo. I'm running 6yo 7.5Kv China diesel in the house, maingay sya pero may concrete enclosure kaya dampened ang noise. Sa farm i'm using mobile(yung nasa trailer) Perkins with stamford 33KV used to run large motor of tunnel vent. The building gets Johnderee 75KV.. All i can say iba talaga quality ng branded gens.
    Regarding KiloVolt rating, IMO when chosing a gen its safe to assume 70% as safe load. Usually 0.8(others have 1) ang PF so kung 10KVA, 8KW ang max load pero bawas pa ng konti around 5.6KW ang safe load. This is useful esp when using inductive load w/c is the common household load (motors of pumps, elevators, compressors) para hindi masira kaagad generator o kukurap-kurap ang output.
    Correct me if im wrong pero nalala ko kaya KiloVolt Ampere sa gensets ay dahil sa Alternating Current reactive ang power when loaded merong apparent at real power.. Para lang din antenna you transmit alternating pulse may feedback o energy returned from the absorbing media kaya kelangan mo ng filters.. depende na sa design kung leading o lagging to compensate the type of load - resistive, inductive, capacitive.
    Jun 2006
    #504
    I think those ryobi's are surplus from australia. I have bought some surplus items from australia and their power supply are are rated at 220v 50hz.
    Baka ganon din yung genset na yan.
    #505
    Sir pa pm naman ng price ng dalawang yan. Thanks po
    Jun 2006
    #506
    Im also interested sa diesel genny. Preferrably 3-5kva. Pls pm the price.
    ok tomorrow morning po
    Jul 2004
    #508
    I finally got a generator. Elemax (Honda) SH3200EX.
    I decided to get this instead of the big ones that can power aircon units because after evaluation the cost of operation, this unit would prove to be the most economical one.
    Pag yung big unit kinuha ko, (6500watts+), more or less I will be spending P5,000+ every 24hours of running time. Dito sa maliit, it would only cost me P1800 to make it run for 24hours.
    So naisip ko, pwede na etong SH3200EX (2,500 watts nominal / 3200 watts max).
    It can power
    1 big ref (21cu)
    1 small ref (12cu)
    2 TV (50"+)
    7x electric fan
    15+ lights
    modem/router/internet system
    etc
    Cost of this unit though is a bit high P45,000 since Japan made sya.
    Dec 2012
    #509
    Where did you get the unit? How's the noise level?
    #510
    Quote Originally Posted by joms View Post
    It can power
    1 big ref (21cu)
    1 small ref (12cu)
    2 TV (50"+)
    7x electric fan
    15+ lights
    etc
    Wow! Mahal na! P30k+ lang bili ko before Sa royal plumbing Sa Binondo.
    Uls, paki post nga yun prices ng 3kva, 4kva 5kva, 6kva and 7kva
    Iniisip ko Kung magdagdag na lang ako ako ng same KVA or upgrade to higher power rating.
    Posted via Tsikot Mobile App
Generator sets
