Page 15 of 46 FirstFirst ... 511121314151617181925 ... LastLast
Results 281 to 300 of 908
    Oct 2011
    #281
    Sir manikis, parang natanong ko na rin sayo ito dati..... but il ask again. advisable ba na may kasama ng ATS sa loob ng genset? or mas maganda na separate ung ATS from the genset? mahal din kasi ung free standing na ATS. kaya i was thinking na mas makakatipid kung kasama na sa genset.
    Aug 2003
    #282
    i asked around, seems mostly china brand na ang binebenta sa evangelista. The few shops that were carrying honda, robin, etc. , sobrang laki ng price diff: for a 5-6kva diesel generator, ~35k lang; equivalent Japan brand nasa 70k upwards .
    Ganun na ba talaga presyuhan ng Japan brands ngayon?
    What engines do Powermate units use?
    Aug 2003
    #283
    guys, i came across some ads on sulit.com, Denyo 6kva diesel nasa 60k pesos. Ok na ba sya?
    Jun 2011
    #284
    mag china ka nalang sir.... ang matitibay na denyo yung malalaking unit...
    IMO same lang ng quality yan ng ibang china made genset like yanma or yangdong...
    saan mo po ba balak gamitin sir? ilang hours ang gamit nyo?
    standby or emergency use lang ba?
    Jun 2011
    #285
    same lang ang price nyan sir retz... advantage ng build in- space saver at nasa loob na kasi ng ats... (less din sa part ng end user) ang cables na gagamitin...
    pati battery charger build in na din... may mga controller na build-in ang battery charger...
    pag dating sa price.. same lang yan sir...
    if you want we can give you a special price sa ats... ilan kva ba usually ginagamit nyo?
    Aug 2003
    #286
    Ang sabi kasi sa akin, most China gensets/engines, aluminum daw ang gamit sa motor windings vs. copper, which is bad..kaya umiiwas ako sa China made
    Emergency use lang sir, planning to run lights, ref, and possibly a 1hp water pump. Definitely going for diesel. Thanks
    Oct 2011
    #287
    Usually sir manikis nasa 250-750KVA ang ginagamit namin. Kung same lang price edi mas maganda kung built-in na ATS sa genset? para hindi na ako bibili separate na ATS. Pag may requirements ako pa quote ako sayo sir.
    Aug 2003
    #288
    sir glenn, san po makahanap nung Yanma genset? Can'd find it in Quiapo or Chinatown
    #289
    ok ba yung Ryobi digital inverter generator? 1KW and 2 KW models? san mura?
    Jun 2011
    #290
    yanma...
    my daughter have small units gas fed... 1kva, 1.5kva, 2.5kva, 3.8kva, 4kva, 7.5kva... according to my chinese friends Matibay daw same quality....
    sobrang dami nilang stock nyan... as-in.....
    mag open ang anak ko ng shop sa may Quezon ave. middle of march sila mag start... malapit lapit sa lahat...
    Jun 2011
    #291
    [QUOTE=badkuk;2289796]Ang sabi kasi sa akin, most China gensets/engines, aluminum daw ang gamit sa motor windings vs. copper, which is bad..kaya umiiwas ako sa China made
    not true po... like cummins gensets, all units is in accordance with the global quality standard of cummins usa sir...
    you can even verify po sa cummins phils. kung original po yun... kung magkaron din ng mechanical problem yung engine... pwede din ang CUMMINS phils ang gumawa po nyan.. provided under warranty pa din yung unit na binile nyo...
    Even UK made PERKINS, German brand na duetz, US MADE CUMMINS, CATTERPILAR, pati mga german trucks and vehicles (MANUFACTURED by weichai) lahat po yan galing china din lang...
    maliban sa US MADE Cummins--- yung cylinder head and engine block manufactured talaga sa US.
    but everything else is made in china na, including the alternator or dynamo (heart of a generator)... the controller (brain)...
    According po sa mga technicians dun sa china... the difference between china made cummins and USA made cummins engine block and cylinder head is the metalurgy.. there's a 2% difference daw po... pero pag dating sa price double na agad ang price ng US made cummins...
    There was a time may nag order po samin ng noozle FOR 1000kva US MADE CUMMINS.... they gave us THE sample noozle... IT reads MADE IN USA... ang sabi po namin... meron kami nyan.. parehong pareho pati part no. etc... PERO managagaling pa ng CUMMINS china.. WE told them pareho lang ang gamit na noozle ng china made and us made cummins....
    ayaw nila maniwala na made in china din yun noozle na nakakabit sa genset nila at galing daw talaga ng U.S. YUN...
    sabi nila PAG U.S. made daw... dapat daw may made in usa na naka engrave...
    NUNG dumating na yung noozle... they compared the two... parehong pareho pati may markings din na made in USA....
    kami kasi sir.. honest seller kami.. kahit naka engrave pa na made in USA PA YAN.. kung sa china namin binile sasabihin talaga namin na made in china din yan... pero ang quality is in accordance with the global quality of cummins..
    YUNG mga generator naman na cummins na pumapalya malamang galing po sa mga gumagawa ng fake na cummins yun sa china... or galing INDIA... OR hindi maganda ang pagka recondition na Cummins po yun at ipinapasa as brand new... OR ppwede din Factory defect...
    Aug 2003
    #292
    sir glenn, sent you PM...
    Eto na po ba yun?
    Yanma Machinery - Diesel Generators
    Grabe pala price diff ng China- and Japan-made...in some cases more than x3 for a 5-6.7kvA diesel unit
    btw, i did some reading on the copper vs aluminum winding thing...came across a paper that says aluminum it not necessarily inferior to copper, depende rin daw sa design ng motor to take advantage/adapt to aluminum windings.
    Jun 2011
    #293
    Eto na po ba yun?
    YANMA? nakita ko na din sa china yan... hindi ko lang pinapancin at hindi ganun kaganda ibenta dito at hindi naman REGULAR NA may bumibile nyan... at maliit lang ang kitaan dyan... mabenta lang yan pag may power crisis at BER months...
    ang mura lang nyan sa china...
    kung alam nyo lang... pag nalaman nyo price baka pati kayo ma enganyo mag invest dyan...
    meron pang tapat dyan daughter ko.. " Derek" china made pero ito usually ang rebrand or rebage ng ibang company tapos sasabihin nilang US OR JAPAN Brand... THEN jack up nila ng 2-3X ang price... actually rebrand din namin ito...
    to be honest hindi pa namin personally subok itong generator na ito... ang balak ko dito gamitin namin ng continues for 2 weeks on prime power... or hangang tumirik...
    Aug 2003
    #294
    sorry sir, akala ko nagcacarry kayo ng Yanma :p i think it's a play on the Yanmar brand. Nung niresearch ko, the engine models they use for their generators match those of earlier(80's) Yanmar engines. Dunno if they licensed the technology or "adopted" it <wink wink nudge nudge>.
    May 2012
    #295
    yanma...
    sir glenn..san po sa Q.A. mag open daughter nyo?
    new arrival from japan -- 400kva nippon sharyo genset
    Mar 2004
    #297
    How much are 10 KVA & 20 KVA gas and diesel generators? If used 2-4 hours per day for a month or two, would a diesel generator still be worth it's price over a gasoline one?
    Jun 2011
    #298
    Quote Originally Posted by skyflakes View Post
    Quezon ave. near corner araneta... DUNAMIS Power
    Jun 2011
    #299
    pag ganyan rating sir.. usually puro diesel engines na po yan...
    mas matibay po d-hamak ang diesel engines compare mo sa gas fed gensets...
    ano po ba ang pag gagamitan ng gensets nyo?
    Jun 2011
    #300
Generator sets
