another question gaano kahaba pwede ko extend yun exhaust? kasi pag umuulan hinde ko malagay sa open space yun gen set namin so sa garage lang eh natatakot ako sa monoxide poisoning, so plan ko extend yun exhaust para pwede ko ilabas sa gate.
Bro.,- I was at ACE Hardware last night and I found a genset that is similar to what I have. Brand is Promate and cost is about P20K. I remember that I bought our genset a decade ago at about the same price. Almost the same, layout and everything, except that this one has a couple of 220VAC outs and a 12VDC out. Fuel capacity is 4 gallons,- so about 15 liters.
For as long as your garage has ventilation, meaning not an enclosed area, then there is no danger of CO poisoning....another question gaano kahaba pwede ko extend yun exhaust? kasi pag umuulan hinde ko malagay sa open space yun gen set namin so sa garage lang eh natatakot ako sa monoxide poisoning, so plan ko extend yun exhaust para pwede ko ilabas sa gate.
Kapag push button, then there is a lead-acid battery that comes with the genset. Now, you have to regularly run it to charge the battery. Typically, diesel fed genset ito. But, I saw a diesel-fed genset (I think 7100VA), that has an option for cranking and push button start sa HandyMan, ATC.. If I remember correctly,- P50K ang cost.At saka yung "push button" starter sana at di yung "de baltak" (crank starting). Magkano kaya yung mga modelo na ganyan? Baka kasi pag nagtagal, baka maputol yung tali na pang-start.
10.4K:shazam:
Bro,- its parts, to my untrained eyes, look the same as the parts of the genset which I own. And, ours is already over a decade-old... Noon, mas maraming brownouts pa sa area namin sa LPC,- like every Saturday from 10PM to 6AM for over half a year, if I remember correctly, due to the Zap-Alab Road widening, where they have to relocate the big electrical posts...
So far, walang breakdown...
Also, since it is rated at 3000VA, then running it at 220VAC out, means that its output current is about 13.6A, so I can just plug it in a regular outlet, while disengaging the main power breaker.
10.4K:shazam:
CVT, yun 20k powermate sa Ace 3KVA lang? meron ba sila 4 KVA? I need to buy another gen set for our other house. masyado ng mahal ang Honda.
saan pa ibang distributor ng Coleman gen set? baka mas mura pag sa labas bilhin compare sa ACE.
just saw a motorstar brand gen set at home depot. P28k+ 5KVA...pwede na kaya ito kesa sa Coleman.
anyone knows about this brand? really need to buy gen set this week na.
5KVA at P28K+ should be a good price, bro... Is it diesel or gasoline-fed? Not sure about the brand, though.... Now, that could support one 1HP A/C...
Anyway, there is a store on the 3rd/4th(?) floor of Festival Mall, Alabang - near the bowling area(?) which sells generators. Forgot the name, though. Maybe someone reading this thread could help id this for us....
10.4K:shazam:
another option saw one this weekend, Coleman powermate, hinde promate ha.
4KVA 27k+ the problem is yun mga outlet niya puro 110V, yun main outlet lang niya ang 220V. brigs and stratton ang engine. ewan ko kung ano engine ng coleman promate. mas ok kaya ito?
At 4KVA and 220VAC out, then max current is 18.2A. For me, this is still pluggable to a regular outlet with a breaker switch of at least 20A, and with your main switch off (very important!). I'd say that this can support a 1HP A/C, plus refrigerator and various lightings.....
Coleman powermate is a good brand (with briggs and stratton engine). And, do not worry about the 100VAC outs. Most probably, the genset was intended for the US market or a country which has its power requirements at 110VAC. One 220VAC out should be good enough...
10.4K:shazam:
ilan kaya wattage i drive ng 3 KVA na fridge? X3 din ba ang start up ng fridge?
Typically X3 ang start up current/power ng compressors. Some are even recommending X5....
Ang laki naman ng fridge ninyo,- 3KVA? Whew!
VA is "also Watts",- the former has reactive(?) components- reactance (typically, inductive),- while Watts is pure resistance (ideal)....
10.4K:shazam:
