Results 1 to 10 of 13
- Sep 2009
- 2
September 14th, 2009 04:02 PM #1To all MB 2.3-16valve owner, Bago lang po ako dito, papatulong sana ako ano ba magandang mga oils para sa engine, differential at transmission para sa 2.3-16valve 190E ko. Bagong bili ko kasi 2nd hand. Gusto ko palitan lahat ng fluids. First time ako mag ka mercedes, from nueva ecija pa ako. Balak ko sana dalin sa manila para mapalitan lahat ng oils, air filter at fuel filter. Anong shop ma recommend nyo? Mahal ba sa CATS sabi nila dun daw casa ng benz. Ano ba mga brand ma recommend nyo para sa oils and filter baka dyan na lang ako bumili sa manila at kami na lang mag palit. Salamat sa inyo.
September 14th, 2009 05:56 PM #2
Hi Jay and [SIZE="4"]WELCOME!!![/SIZE]
I would suggest Mobil1 20W-50 or Lubro Moly 5W-40. From experience and based on availability here, I use 10w-50 or 15w-50 for cars with high performance engines --- like your 2.3-16.
Since you are still coming from far north, I would suggest a friend's shop that are really good in MBs. Shop's name is:
MIKE AND THE MECHANICS
# 71 Kamuning Road, Quezon City (between 11th Jamboree and Sct. Ybardolaza / Judge Jimenez)
(02) 9273465
Look for Mike Lugtu.
- Sep 2009
- 13
September 15th, 2009 01:36 AM #3Hi jay, regarding change oil filter and fuel filter, kaya ba ng DIY yan or it should be a benz specialist ang gumawa? same lang ba ang oil and fuel filter nyan sa regular MB190e 2.3 ?
- Sep 2009
- 13
September 15th, 2009 12:53 PM #4Where can i buy original parts for MB 190e ,like oil fiter,air filter and fuel filter, breakpad. I called up delodur they ony have replacement, is it ok if i use replacement parts? Wag lang po sa CATS ha super mahal kasi dun.
TIA
November 19th, 2009 04:43 AM #5
Try Royal Dragon at Linaw st. Quezon City. 7426893 look for Edra.
RLC Chuatoco 4116390 look for Mang Bert.
Lemforder is the OEM brakepads for MB although you can use Bendix, FB Biltiens. Kaya ng DIY ang change oil and filters. Pag gear oils chage sa gas station or any indie MB shops pede rin. If you still have the owners manual nandun an specs on how much oil you need and their viscosity rating.
- Jul 2008
- 173
November 27th, 2009 12:45 PM #6Susme naman, bakit ka pa pupunta pa sa Maynila para lang palitan ang fluids ng MB 190 mo? Di naman siguro masyadong backward sa lugar nyo para di magawa ito locally. Madali lang magpalit ng langis at filter ng oil, kasama na rin dito ang magpalit ng water coolant, at saka transmission oil. Ang advise ko lang na medyo dalhin mo sa gumagawa ng MB talaga ay ang tune-up, valve adjustments, at saka anything to do with engine adjustments...Brakes, alignment, etc. puwede mo na lang dalhin sa local shops..Yung AC medyo mahirap ding gawin ng di sanay sa MB kasi maraming mga sensors na di pamilyar sa basta AC Technicians..
- Oct 2005
- 7
April 20th, 2010 12:43 AM #716v owner here. I use liqui moly 10w-40 hd for the engine, redline mtl for the tranny, redline shockproof light weight for the diff. I use BMW coolant. Kayang kaya DIY sa oto na ito, as long as you have proper tools. The immediate concerns for most 16v owners are the SLS system, shifter bushings, lap timer, ICV, cold start valve and the Air fuel mixture. I am keeping mine and now have spent a lot for the car. I changed the fuel system (70L tank, vdo fuel level sensor, governor, fuel pump, fuel relay, injectors, etc), delrin shifter bushings, SLS delete, bilstein sport shocks, h&r race springs, sls pump cover, braided brake lines, 500e w124 f/r brake upgrade.. I am now waiting for my sway bars to arrive too. I have a lot of parts still lying around that I haven't installed yet due to a busy schedule. I suggest you visit www.190rev.net for tips and inquiries for maintaining your 16v. Now, my car does not ride like a benz, medyo nasa harsh side na siya but on sierra madre fun runs, ahhhhhh... rewarding lahat ng ginawa ko.. never tried it on the track though. Addicting ang hagok niya.. hehe..
- Aug 2009
- 29
April 27th, 2010 12:03 PM #8
- Oct 2005
- 7
- Oct 2005
- 7
Kung walang spare tire, invest on a Inflator kaysa sa sealant. Inflate the flat tire +10 psi than...
Liquid tire sealant
