Results 1 to 19 of 19
    Jan 2010
    My 230e misfires, stalls, drives rough, chokes, hesitates acceleration.
    After days of finding out with different mechanics, we came to a conclusion that the spark plug no. 3 (always wet with oil and does not work after a few kilometers of run from engine start) is caused by a problem inside the valve or gasket (maybe piston). So, we have decided to have it overhauled. Now, would anybody care to share their knowledge:
    -Where can I have my 102 engine overhauled/top?
    -How much would it cost me?
    -Who has experience having his benz engine overhauled?
    TIA
    Jan 2010
    By the way, the spark plugs looked like the "oil fouled spark plug" in this picture:
    http://www.aa1car.com/library/s_reading_spark_plugs.jpg
    Feb 2005
    McBenz: From where are you? If you're in QC, you might want to try visiting Mike and the Mechanics. Shop is located along Kamuning St. From EDSA, it should be on your right.
    Jul 2006
    you have pm.
    Jan 2010
    Pinasok ko sa sunshine motors yesterday. The mechanic did some troubleshooting on the fuel distributor. Okay na ulit takbo. After taking it home (Fairview) okay pa din sunog ng spark plug. So, I guess it's just the fuel distributor. Brand new daw nun pag nasira is 30k.
    New problem: Exhaust Tunog jeep na sya... (paahon na jeep) And quoting from Mike Lugtu "tunog bangka"
    Feb 2005
    Quote Originally Posted by McBenz View Post
    Hehehe! Check this website out. A good number of co-enthusiasts has actually tried using their products (as an alternative to OEM muffler)
    http://www.mufflerland.com.ph/
    Mura na yung quote ng Sunshine na 30k for a brand new fuel distributor, alam ko nasa mga 75-80k ang brand new nyan for a M102 engine, baka surplus yang 30k pero kung talagang brand new yan, bilhin mo na yan para pang spare.
    Feb 2005
    Quote Originally Posted by ronw123w124 View Post
    +1 to this. Some guys we know even have a difficult time looking for a fresh FD. Given I drive a gasser and an extra FD comes up, I'd grab on to to it too.
    Jan 2010
    Thanks for the tips and info.
    TIA
    ganitong ganito din nangyari sa w201 190e ko. eksakto sparkplug number 3 din yung nababasa ng oil after a few km of driving. . . . nagstart yung problema nung sakin, hard starting, after maayos yung hard starting, pumapalya na yung makina, then nadiscover ko na nababasa na nga ng oil yung sparkplug number 3. . . ang culprit bad valve seals, and since bubuksan na rin yung makina ko pinapalitan ko na rin yung mga piston rings and main bearings since malapit na ring bumigay para isang bukasan nalang. . . sa charon trading along congressional ave. ko pinagawa yung auto. . . mura na mabait pa yung mayari. . . 1 week nang nandon yung auto ko hopefully next week makuha ko na. . . look for charlie bro kung pupunta kang charon and tell him nirefer ka ni Jr Onia, I'm sure bibigyan ka ng big discount nun. . .
    Jan 2010
    *deadly elegance: Thanks for your info and tips.
    Ayaw i-overhaul ng sunshine motors yung benz ko. As I have said, instead, nag-adjust sila sa fuel distributor. Okay na ulit yung takbo at wala na yung palya na parang nasisinok at hesitant mag accelerate at all gears and speeds. Ngayon 1 week na sya maayos ulit takbo, dinala ko na ng antipolo from fairview and to bacolor, pampanga and back. Okay pa din so far.
    Checked on the spark plugs kanina at maganda pa din sunog nilang apat (red-orange kulay) unlike dati na para silang may sakit at nangingitim yung gitna.
    Someday I know i'll have this engine overhauled. Pero sana not at the soonest. Plan ko budget-an muna yung fuel distributor at alternator eh hehe..
    Goodluck sa overhaul mo and I hope maging okay na din ulit takbo nya!
    Cheers!
    baka meyle ang brand nun FD na yun hehehehe.
    Cheers!
    aw. . . sorry kala ko kasi consistent na nababasa ng oil yung sparkplug tulad nung sakin, buti nalang hindi mo dinanas yung gastos ko. . . sana nga bumalik yund dati nyang takbo i really love this car kase. . .
    Jan 2010
    Quote Originally Posted by afrasay View Post
    Not sure kasi diko naman natanong yung brand... sana mas magandang brand anyway, no choice naman ako if ever.
    Quote Originally Posted by deadly_elegance View Post
    Magiging okay yan one way or another.
    Oct 2005
    Cheers!
    Bro, sino pala contact mo sa sunshine motors? i have the same problems
    Jul 2006
    Anong klaseng adjustment ginawa sa fuel distributor?
    EHA valve baka na-adjust, or yung air meter tower.
    Jan 2010
    Quote Originally Posted by mbeige View Post
    Niluwagan yung apat (?) na connectors from the FD then the mechanic observed the flow of gas. Sabi nya yung isa medyo mahina ang buga. I don't see any difference though maybe it's just me. Anyway, pinukpok nya ng konti yung side ng medyo mahina daw ang buga using (i forgot the tool). Then ayun okay na daw yung buga. He tightened the screws back in place.
    Then yung sa AF meter tower naman medyo inikot-ikot nya left.. right.. i forgot basta kinalikot nya for a while. Then punta sa likod sa exhaust inaamoy parang adik na nga ang dating eh.
    Yun ang mga ginawa nya. Then back to "normal" na yung acceleration.
    It's been almost 3 months (?) since that palya moments.. Okay pa din takbo. Gas consumption naman ang aayusin kasi medyo matakaw * 7km/l.
    Cheers!
    Jul 2006
    Matakaw gas consumption kasi tantsahan lang ginawa niya when adjusting the A/F tower.
    May device na pwede ikabit sa diagnostic port (tabi ng trigger box) to see what the range is, tapos adjust A/F ratio accordingly. Ganun ginawa sa akin. Delekado rin amuyun yung exhaust, CO poisoning mangyayari.
    Dapat check muna EHA valve (nakakabit sa fuel distributor) bago adjust yung air meter tower.
    Aug 2009
    Cheers![/quote]
    Bring it at Delodur libis they have CO tester there for proper AF mixture, less than 1k yata ang price.
Engine Overhaul
