The alternator is designed to give enough power at specified idle speed say 900rpm.. lower rpm say 600rpm then alternator charging will cut out
Now this is something new to me... I never knew this because whenever:
1. I rev my engine, the ammeter gives a higher reading
2. I test the alternator coming from a repair, the alternator technician places the alternator in a test bench and shows to me the capacity of the alternator but above 2,000k.
Sent from my ASUS_X00QD using Tapatalk
an ammeter in the car will settle the question of whether a 60 amp alternator will alternate to deliver full 60 amps at idling,
or whether the engine has to be revved for the alternator to produce that much oomph.
alas, gauge meters have been largely replaced by idiot warning lights.
i do not know about today's modern cars, but if memory serves,
i remember noticing in our old aftermarket-ammeter-equipped car, that one has to rev the engine a bit, for the alternator to deliver higher amperes.
Maybe this can explain it
MATEC Web of Conferences › ...
Web results
Experimental study on the effect of alternator speed to the car charging ...
Hi mga sir sorry for the noob question but I just want to ask if anong papers ang kailangan dalhin sa casa to avail the free pms? do I need to bring the service booklet? If wala ba yun hindi free ang pms? thanks
bring your service booklet, and a xerox of your OR CR.
bring also your car. heh heh.
make a phone-in appointment, to avoid waiting long.
arrive at least 15 minutes before your appointment time. they will usually tell you this. follow it, because your slot might be given to someone else, if you don't come reasonably on time.
harden your heart, so's you not get swayed by sales talk and consequent additional payment.
bring something to do. you might not like the program on the monitor.
bring money and/or your credit card, for "the un-foreseen".
good luck.
Hi all,
Planning to have my 90K PMS done outside CASA(probably either SpeedyFix or Motech) next week.
I will bring my own engine oil and mazda oil filter.
Aside from the usual change oil, anything need to check? Should I ask for Multipoint inspection and have them check the brake fluid?
How about brake cleaning?
Air filter and aircon filter are still good since I just replaced it last April 2019.
Car is 2015 Mazda 3 2.0.
Thanks in advance!
Guys any idea how much is the air filter and cabin filter for mazda 3 skyactiv in casa? Thanks.
Air filter - 1.9K php
Aircon filter - 3,242 php
Question on maintenance
I'm currently using Vic aircon filter priced around 1.2kphp ata. Bought it sa Lazada.
