delete.
sorry.
changed my mind.
delete.
sorry.
changed my mind.
Sobrang mahal pala ng PMS ng Mazda ano?
Compared to my Civic, with similar items, it costs less than 10k.
The quote from 1 dealership isn't enough basis for a general conclusion. I always DIY our maintenance, but when I realized the lone local Mazda dealership here had reasonable labor & parts rates, that took away whatever incentive self help would've given. Trick is to ask, opt....not be dictated. [emoji4]
Finally did the PMS after 1 and a half years. Here's the breakdown after Yojin 3 expires. I had all the checks done and also bought and replaced the front windshield wipers (never been replaced since buying the unit). I wouldn't have done some of those as advised by travs but since I haven't brought it in for a year and a half I figured it wouldn't hurt to have the others done.:
ang mahal pala after ng Yojin-3. (still have 2 years to go)
Pero sa PMS list with Yojin-3 wala naman yung mga xxxxx cleaner.
At usually nasa less than 5k lang ang total bill.
Oil + filter change lang ba ang required?
Good am sir, just want to ask if kailan dapat magpalit ng ATF mazda 3 3rd gen? thanks
Just got mine done yesterday, initial quote with all the BS is 17K+, told the SA don't need no decarb, it's a waste of money, to make the story short, managed to trim it down to 12.5K.
Previously I had it done outside for half the price but the not so good experience (leaking oil), I think I'm better off if done in the casa, hence.
Things that Casa wanted me to replace, except for the front shocks, are they really necessary for a 5 year old less than 50K mileage?
The below will make you weep.
PARTS
1 B60S34350G ARM ( L ) LOWER 1.00 PC 17,714.00 17,714.00
1 B60S34300G ARM ( R ) LOWER 1.00 PC 17,714.00 17,714.00
1 B45A34170 LINK CONTROL (L) 1.00 Can 1,934.00 1,934.00
1 B45A34150 STAB LINK FRT (R) 1.00 PC 1,933.97 1,933.97
1 BHS234700A SHOCK R FRT 1.00 PC 9,263.00 9,263.00
1 2ZSV0028ZD2P0A ATF FLUID FZ 7.00 LI 613.01 4,291.07
1 KD4561J6X FILTER COOLING UNIT 1.00 PC 3,234.52 3,234.52
1 KD3534380C TOP MOUNT 2.00 PC 3,101.00 6,202.00
1 FZ0121500 STRAINER OIL 1.00 PC 2,829.00 2,829.00
1 BJJ369181C SIDE MIROR L 1.00 PC 12,901.42 12,901.42
1 BHS234900A DAMPER L FRT 1.00 PC 9,263.00 9,263.00
Labor cost not yet included.
I think the casa is just following their SOP i.e., replacing parts after 5 years even if not really warranted.
suspension parts? i'd replace them only if they were already showing signs of significant wear, i.e., lagutok.
shocks? only if they don't un-shock anymore.
side mirror? what's wrong with it? and it's probably cheaper, off-casa.
Whoah!!! How are you using your car? Offroad? Rally? Are your struts/dampers leaking? My 3 turned 5, too, clocked a bit more than yours & it's silent & solid. I periodically check alignment & the numbers remain usually w/in spec & dial them back to precise toe & cam numbers.
I even found the stock dampers overbuilt...they refused to die & I had an unopened present of Koni FSDs waiting in the parts bin...[emoji38]
