Results 21 to 30 of 39
- Nov 2007
- 31
December 26th, 2008 10:28 AM #21
December 26th, 2008 12:02 PM #22
December 26th, 2008 06:47 PM #24
RR27: medyo mahal yang mags for a 15 incher... 17" mags would normally range from 26K, Rota brand... if i were you, i would opt for 17"... merong Innova member na pareho nyan ang design ng mags pero 17".
December 26th, 2008 09:02 PM #25
March 17th, 2009 09:48 AM #27
sa lahat po na nag upgrade from stock to 17 inchers... kumusta po ang FC ninyo. planning to upgrade din kung may budget, gas fed kasi ang akin kaya medyo concern ako sa FC maraming salamat po.
March 19th, 2009 12:12 AM #28
Tsikot Member Rank 3
- Aug 2003
- 1,251
March 20th, 2009 08:29 PM #29i use the same oem mag wheels, but upgraded from the oem 205/65 r15 tires to 205/70 r15. Gives better ride than the 65 series oem tires, and the tires, being bigger, takes care of that "puny" look.
And the 70 series tires, even with higher sidewalls than the 65 series, are cheaper than the oem 65s.
It's another story if you want to change your mags, though.
April 13th, 2009 06:16 PM #30
Anong size need nyo? May nabibili ako online from lazada. Baka malapit lang sa inyo yong store...
Finding the Best Tire for You
