Results 11 to 20 of 54
August 2nd, 2017 02:54 PM #11
August 2nd, 2017 02:59 PM #12
I've tried the footpumps, and the 12 volt DC things, hindi tumagal lahat sa akin.
So I bought a 1/4 HP Vespa compressor off OLX for php 4K.
Problem solved.
- Apr 2010
- 739
- Jun 2017
- 153
- Jun 2017
- 153
August 2nd, 2017 04:05 PM #15Ano power source niya sir? Pede ba siya isaksak dun sa mga wall outler or sa 12v nung car sinasaksak? I wouldn't mind going through that price as long as tatagal at maganda naman ung
item.
EDIT: BTW sir just checked olx may mga liters liters siya ano ibig sabihin nun? Nauubos po ba ung air then pede rin siyang refillan?
Thanks sir.
- Feb 2015
- 174
August 2nd, 2017 09:26 PM #16Yung photo sa first page. Yun na yun. Same gamit ko. So far ok naman.
1psi = 10 pumps based on my usage.
Sent from my SM-G532G using Tsikot Forums mobile app
- Feb 2014
- 2,537
August 2nd, 2017 09:56 PM #17
August 2nd, 2017 09:58 PM #18
Eto ang gamit ko (bought at Ace for around Php1,7k):
Have only used it for topping up so far. Wala siyang deflator so kung na-overinflate ka sa gas station air fill-up, manually mo muna siya babawasan ng hangin saka inflate to your preferred psi. Features include the digital tire pressure gauge and a 5V USB outlet for charging your electronic devices, though you still need to plug it to your car's 12V cigar lighter outlet.
Cons include the 40~50 psi max pressure and not being able to inflate from flat. Haven't tried to inflate a flat but I think it's doable as long as there's 5~10 psi left and you inflate in short bursts.
Link for the user manual is here for more info: Michelin 12264 User guide
There's a higher capacity and more heavy duty model though it's already around Php2.3k++ yata:
- 52,734
August 2nd, 2017 10:13 PM #19
- 52,734
August 2nd, 2017 10:15 PM #20
The serpentine belt is still okay, usual consumables (air filter, oifl filter, cabin filter) got...
Ford Everest 2015
