Results 2,001 to 2,010 of 2394
March 6th, 2020 07:32 PM #2001
Fleva wasn't worn out but 2 tires had sidewall cuts due to a pothole so had to change them, changed all 4 already to be consistent. Still had 3.5 mm tread left so they would still last another 10,000 km or so.
I would also do triple-digit speeds on McArthur and I used to drive 500-800 km a week. No issue with the tires.
- May 2014
- 1,318
March 6th, 2020 08:15 PM #2002Yokohama Advan Fleva V7 1 test and review of the summer tire Yokohama V7 1 | AllTyreTests.com
Here is the chart for wear projection. About 35000kms.
It already has a comparo in the site for other similar performance tires but federal wasnt there.
If a review from same site that has both.
Federal 595EVO - Tyre Tests and Reviews * Tyre Reviews
Yokohama Advan Fleva V701 - Tyre Tests and Reviews * Tyre Reviews
Based on those reviews, if priced close, go with yokohama. The federal doesnt have good grip in the wet as a start.
March 7th, 2020 12:28 AM #2003
My firsthand experience with the V701 is that it lasts longer than 35,000 km.
I got mine at 28,000 km and replaced at 67,000km (39k km total) but with 3.5mm left which is at least 30% tread remaining so the tires would have lasted 55,000 km.
For reference, this is the conversion of % tread remaining vs mm tread remaining:
- Jan 2020
- 26
March 7th, 2020 07:59 AM #2004
March 7th, 2020 12:29 PM #2005
Because you're comparing it to better, more expensive tires like the Michelin PS4, Conti Sport 6, Goodyear Assymetric F1, etc.
But if you compare that to other cheap brands like Achilles 2233, Accelera Phi, Neuton NT5000, etc, it performs just fine.
I've won races with my V701. Performance isn't as good as the other tires above, but you won't notice unless you drive fast in corners. Kung McArthur/NLEX lang, no difference at all.
If you really want high-performance tires but kapos sa budget, you can get GT SX2 or Achilles 123S. These are very grippy tires that are great for track use but are have much more road noise and will not last as long as a road tire like the V701.
- Jan 2020
- 26
March 7th, 2020 07:31 PM #2006
March 7th, 2020 08:28 PM #2007
For the same price as the Fleva V701, would also consider the Kumho Ecsta KU39. Had them before the Fleva, roughly the same price (5.2k vs 5.5k) and it had better grip.
Fleva would probably last longer though (it's always a tradeoff between grip and longevity).
Kumho Ecsta KU39 - Tyre Tests and Reviews * Tyre Reviews
In any case, the V701 is a pretty safe choice and decent value for its price.
- Jul 2011
- 78
March 9th, 2020 12:50 PM #2008I would like to ask for recommendations for the replacement of the 2 front tires of our Innova. Daily use involves driving my niece to and from school everyday (less than 10k distance) with an occasional visit to the province (Laguna) once or twice a month.
- Jul 2009
- 3,604
March 9th, 2020 12:55 PM #2009Marami ako napapansin na innova mabilis mapudpod yung gulong...
I'm GUESSING it's a combination of having passenger car tires on a heavier MPV.
Suggestions: replace with STOCK tires (which aren't bad!)
Or: SUV or Light Truck tires (like what you get on the hiace) if you can find it in the right size.
Whatever you do, remember to have the NEW TIRES PUT AT THE BACK!
March 9th, 2020 01:26 PM #2010
Xiaomi E-Car
