Page 7 of 9 FirstFirst ... 3456789 LastLast
Results 61 to 70 of 86
    Jul 2004
    #61
    mga bro ok din ba ang 17" sa van like starex 8 seater? as of now my brother using 15" at gusto nyang magpalit ng 17" para maiporma kahit konti.
    #62
    tsikot gurus
    question will the 15 inches stock mag wheels of the CRV fit a honda civic esi?? will u need to change the tires or align anything?
    thanks
    #63
    Maliit masyado ang wheel well ng Starex vans. Pwede sya maglagay ng 17s but he'll have to match it with 225/45 tires, to thin for a van, imo. Or even 215/50 for that matter kung may scrubbing.
    May nakikita akong madalas sa Mendiola area, lowered Starex van with 17s kaso masyado yatang matigas yung springs, umaalon buong van pag tumatakbo.
    #64
    topgun::: nope, di po kasya kasi 4 holes ang civic, 5 holes ang crv.
  5. #65
    Ok na sakin yung 15" rims na second hand, sa Adventure ko sana kakabit, I'll think I'll spend my money on good tires.
    #66
    salamat po ng marami ssaloon thanks a lot for ur info san kaya makakakuha ng second hand na SIR mag wheels na 15 inches
    Jan 2004
    #67
    Originally posted by GlennSter
    shempre mas mabilis po ang 15's kasi mas konti ang iniikot niya....
    although some claim na mas matipid naman sa gas ang 17's since malaki ang nasasakop niyang area...i dunno.
    pero im quite sure na mas mabilis ang 15's.
    sir glenn:::
    heto po ang aking natutunan sa math.
    the perimeter(distance travelled by the tire per revolution) of a circle(or tire, in this case) is calculated by the formula 2*pi*d/2
    pi=3.1416
    d/2=diameter of the circle divided by 2 or the radius
    now for a 15 inch tire: 2*pi*7.5 = 47.124 inches
    for a 17 inch tire: 2*pi*8.5 = 53.4072 inches
    if the rpm is kept constant, it is very evident that the travel of 17 inch tire is farther than the 15 inch tire.
    pero kung parehas lang tire diameter ikakabit, the rim size cancels out.
    my .02 dollar po ser.
    May 2004
    #68
    TIRE SIZE CALCULATOR para mas madali.
    http://www.miata.net/garage/tirecalc.html
    May 2004
    #69
    which makes me think that if you change the overall tire diameter from stock to 17's, your odometer's reading will be off by, say, a foot for every rotation. right?
    #70
    Originally posted by quindoyos
    sir glenn:::
    pi=3.1416
    math!?ano po iyon!?nakakain ba yun!?!herhehrherh..not my fave subject.
    but yes.based on your calculations, at kung pagaganahin ang common sense, kung pareho ng diameter ang gulong (goma) mismo, the rim size is cancellable...
    pero teka...mali ba sinabi ko?tama naman diba?mas maraming distance= "mas malaking area ang nasasakop niya" diba pareho lanbg po iyon?
    ahihihihi..ikaw kasi hiniritan mo ako ng math nagkagulo tuloy utak ko!!ahrhrharh
17" rims or 15" rims?
