Results 61 to 70 of 86
- Jul 2004
- 105
July 22nd, 2004 02:01 PM #61mga bro ok din ba ang 17" sa van like starex 8 seater? as of now my brother using 15" at gusto nyang magpalit ng 17" para maiporma kahit konti.
July 22nd, 2004 02:16 PM #62
tsikot gurus
question will the 15 inches stock mag wheels of the CRV fit a honda civic esi?? will u need to change the tires or align anything?
thanks
July 22nd, 2004 02:20 PM #63
Maliit masyado ang wheel well ng Starex vans. Pwede sya maglagay ng 17s but he'll have to match it with 225/45 tires, to thin for a van, imo. Or even 215/50 for that matter kung may scrubbing.
May nakikita akong madalas sa Mendiola area, lowered Starex van with 17s kaso masyado yatang matigas yung springs, umaalon buong van pag tumatakbo.Last edited by Ungas; July 22nd, 2004 at 02:25 PM.
July 22nd, 2004 02:57 PM #65
Ok na sakin yung 15" rims na second hand, sa Adventure ko sana kakabit, I'll think I'll spend my money on good tires.
July 22nd, 2004 07:13 PM #66
salamat po ng marami ssaloon thanks a lot for ur info san kaya makakakuha ng second hand na SIR mag wheels na 15 inches
July 22nd, 2004 07:50 PM #67Originally posted by GlennSter
shempre mas mabilis po ang 15's kasi mas konti ang iniikot niya....
although some claim na mas matipid naman sa gas ang 17's since malaki ang nasasakop niyang area...i dunno.
pero im quite sure na mas mabilis ang 15's.
heto po ang aking natutunan sa math.
the perimeter(distance travelled by the tire per revolution) of a circle(or tire, in this case) is calculated by the formula 2*pi*d/2
pi=3.1416
d/2=diameter of the circle divided by 2 or the radius
now for a 15 inch tire: 2*pi*7.5 = 47.124 inches
for a 17 inch tire: 2*pi*8.5 = 53.4072 inches
if the rpm is kept constant, it is very evident that the travel of 17 inch tire is farther than the 15 inch tire.
pero kung parehas lang tire diameter ikakabit, the rim size cancels out.
my .02 dollar po ser.
July 22nd, 2004 08:30 PM #68
TIRE SIZE CALCULATOR para mas madali.
http://www.miata.net/garage/tirecalc.html
- May 2004
- 36
July 22nd, 2004 09:39 PM #69which makes me think that if you change the overall tire diameter from stock to 17's, your odometer's reading will be off by, say, a foot for every rotation. right?
July 22nd, 2004 10:14 PM #70Originally posted by quindoyos
sir glenn:::
pi=3.1416
but yes.based on your calculations, at kung pagaganahin ang common sense, kung pareho ng diameter ang gulong (goma) mismo, the rim size is cancellable...
pero teka...mali ba sinabi ko?tama naman diba?mas maraming distance= "mas malaking area ang nasasakop niya" diba pareho lanbg po iyon?
ahihihihi..ikaw kasi hiniritan mo ako ng math nagkagulo tuloy utak ko!!ahrhrharh
Automatic po Sir
