Results 81 to 90 of 95
- Nov 2019
- 6
November 7th, 2019 11:39 PM #81
Ask ko lang po, ano po symptoms sa secondary clutch nyo? nagpalit kasi kami ng kit lang kasi may tagas secondary, pero sinabay na din palit ng transmission fluid(using same as engine oil - Mobil Devlac MX).
Pero after this medyo hindi na smooth ang pag change ng gear at meron parang feeling ng kumukulo kapag sa dulo ng press ng clutch pedal. Baka po meron may idea sa inyo, makatulong sa amin, kasi hindi ko alam kung saan issue kasi wala naman tagas yung clutch fluid at hindi nagbabawas.
November 13th, 2019 09:13 PM #82
ggod day sir.
1. may resistance na ang pag shift hindi na siya smooth. primary ang pinalitan ko.
2. ang alam ko iba ang engine oil sa transmission oil
3. hit and miss ang repair kit may matagal masira at may madali. better if you save up and
palitan mo na lang ng bagong replacement part ask mo sa mechanic mo yung brand he
should know.
hindi crosswind ang gamit ko pero generic naman ang issues mo i think kahit anong unit same lang ang principleLast edited by bleem002; November 13th, 2019 at 09:19 PM.
- Jan 2008
- 4,726
November 13th, 2019 09:48 PM #83
- Nov 2009
- 3,485
November 13th, 2019 10:00 PM #84
November 14th, 2019 11:23 AM #85
- Nov 2019
- 6
November 16th, 2019 05:28 PM #86
- Nov 2019
- 6
November 16th, 2019 05:40 PM #87
Salamat po sa reply and tulong.
Nagbleed na po ilang beses na try bleed, then observe kung magbawas din pero wala naman bawas.
observation ko lang is primary master na kapag alisin ang cover ng container + press ang clutch bubulwak yung hangin. Normal po ba ito?
and yung nararamdaman namin na kunting kulo pag full press ang clutch, nararamdaman ko lang sya kapag buhay ang engine. kapag off naman, wala naman.
thinking kung may problema na talaga ba is:
1. Primary master (kasi not sure if dapat ba talaga magbuble ng air kapag press yung clutch while open yung cover (for observation purpose kaya open namin) - not sure if normal dahil sa pressure
2. pushrod - baka maiksi po kaya yung nasama sa kit na pinalit kaya baka nasasagad yung clutch primary at secondary
3. Baka po may hangin pa nga din, pero ilang beses na din nga po bleed eh.
Another update, is kapag adjust kunti ang push ng clutch pedal adjustment(bawas sagad) nabawasan naman yung feeling ng kulo sa feeling while pressing the clutch, pero hindi smooth shifting, may sabit na kailangan slowly mo alalayan para pumasok at hindi magreeerrrr while shifting.
sana po naipaliwanag ko mabuti at may makatulong pa din.
- Nov 2019
- 6
November 16th, 2019 05:46 PM #88
sa Casa po kasi, same as engine oil din po nakalagay sa list ng gagamitin nila as per quoted last time. Checking din po sa mga forums.
medyo nagisip lang po talaga kami after mapalitan yung secondary at transmission oil, meron po na ganung feeling na kapag press nyo yung clutch while buhay makita, merong feeling na parang kumukulo (mahina naman pero observe na seems hindi normal). nakakapagshift naman gear, minsan lang hindi smooth. We check naman ang fluid wala bawas naman. ilang beses na din bleed at nagmove naman yung clutch lever sa ilalim. may pwersa naman ibig sabihin galing sa secondary to push the clutch lever.
- Nov 2019
- 6
November 16th, 2019 05:47 PM #89
November 17th, 2019 05:47 PM #90
working on the principle na dapat walang hangin ang system, IMO kapag bubulwak
may hangin. i would recommend you to find a better mechanic kasi your ride still
gives you some concerns kahit inayos na nya. would you like to try zix performance?
(facebook) the shop gets great reviews. yung owner ang mekaniko doing hands on
repair at times and gives good advice. parang ordinary talyer ang prices pero tops
ang quality ng service sobra pa sa casa if you are lucky nag papa pizza pa siya.
he handles suvs,all makes
siya nga. i tweeted the mmda and they replied it's suspended nga.
Traffic!
