Results 581 to 590 of 640
- Sep 2010
- 129
July 8th, 2011 01:15 AM #581Thanks for the info Uncle Nick, nice to hear from you again.
A visual and touch inspection show no damage to the belts so far, and i reckon they are still working together - either of them is still within the allowable looseness anyway.
Will try doing your tip if one breaks...i pray that the "closest lady" wont break my neck instead, hakhak!
- Feb 2010
- 13
January 30th, 2012 01:41 PM #582Hi fellow crosswind owners.
Hope to get some advice on my vehicle. I own a 2003 Crosswind XUV AT. Bought it 2nd hand last 2008 and it ran for 70k kms already. Current ODO reading is at 106,000kms. Recently, I encountered a "sudden loss of power" when I was traveling at about 80kph pero di naman namatayan. I wasn't trying to overtake, cruising lang. parang nasinok tapos wala na - back to normal.
The other day, one my way to the office, traffic along c5 so mabagal lang ang takbo. nung paakyat na ako sa c5 flyover (pasig / URC area), hirap umakyat si crosswind. parang di nag-do-down shift to a lower gear. AT transmission ko. I tried putting it in L or 2 but no difference. tinabi ko, turned off the engine and then turned it on again. ayun - ok na. it shifted ok.
Any inputs on the possible culprit. would you think an ATF change would do the trick or ATF dialysis na? Could it be the fuel injector also or possibly oil pump?
TIA.
- Sep 2010
- 181
February 1st, 2012 04:49 AM #583eto lang masagot ko bro...as per my experience...try mo palitan ng air filter muna, baka kasi tiklop na yung paper element sa air filter mo,kaya parang nahihirapan humigop ng hangin...and baka kelangan mo na magpa valve tappet(valve clearance adjustment)...palinisan mo din yung primary feed pump and water separator...kayang kaya sa mga shop yan...wag na sa casa,kasi mahal dun...ako gumastos lang ng 1K dyan,may libre pang pakargang freon...
- Sep 2012
- 14
November 29th, 2012 02:56 PM #584
- Jan 2011
- 108
December 1st, 2012 05:33 PM #585boss, hihingi po sana ako ng advice regarding sa 2005 isuzu crosswind ko. Sobrang tagtag na po kasi lalo na sa likod na part. ano po bang mabibigay niyong advice or pwedeng gawin? palitan ng shocks na mas malaki? pabawasan yung leaf spring? or anything. Further question ko po pala, regarding sa towing hitch, nkakatulong po ba magabsorb ng shocks yung towing hitch? sabi po kasi ng iba ganon daw yun. TIA po fellow crosswind owner, pasensya na po pamana lang kasi saken yung crosswind kaya wala din ako masyado alam regarding those
- Jan 2011
- 108
December 1st, 2012 09:50 PM #586kuya, ano pong mga bulbs ang nakapasok sa 2010 isuzu crosswind headlights assembly? may h4 po ba dun? or h7?
December 2nd, 2012 01:51 PM #587
Tanong ko lang po sana about sa body color ng crosswind xuvi 2004 model, kc po yung kulay nia ay orange (original paint daw), kaso po yung nasa o.r nia ay glucone green, nung tinanong ko dun sa seller, ganun po daw talaga yung color, kahit nakikita mo orange ay green daw talaga yun?? I am so confuse po..pls help me, bago ko po kunin yung sasakyan..
thanks in advance..godbless po
December 2nd, 2012 03:48 PM #588
http://imageshack.us/photo/my-images/834/crosswind.jpg/
tanong ku lang po kng ano po color nitosa isuzu crosswind xuvi 2004? i really need your advice
thank you po....
December 3rd, 2012 01:51 AM #589
- Jul 2012
- 56
December 3rd, 2012 08:24 PM #590dapat flexiride na crosswind mo kasi model 2005 yan. dyan nagstart na year model ang magandang suspension ng isang crosswind on XUV model or sportivo or XUVI, but dunno on other variants.anyway you may check first of the ff:
>leaf spring rubber bushing sa may shackle baka worn out na.
>shock absorber baka may leak na, o may langis dun sa body ng shocks.
>dapat 5 leaf spring each side(RR and RL) yan ride mo, kasi saken XUV 2005 5 leaf spring. perhaps pa-check mo rin tension of leaf spring.
>then used double action shocks. pwde din gas-a-just.
towing hitch i'd no idea.
hope this will help bro.
Kung walang spare tire, invest on a Inflator kaysa sa sealant. Inflate the flat tire +10 psi than...
Liquid tire sealant
