Results 211 to 220 of 640
- Apr 2009
- 36
June 7th, 2009 10:16 PM #211i just change oil yesterday sa friend ng erpats ko sa banawe, ginamit namin na oil is enoc vulcan 550x, sabi raw maganda raw etong brand, pero parang ngayon ko lang kc narinig ito. anyone have use this brand ano pong experience nyo? and how much nyo nakuha? as of now wala naman akong napansin na nabago sa engine ko.
June 14th, 2009 01:41 PM #212
mine is an XTO a/t 2001, mileage 94k. stock pa. as compared to my corolla, mabilis naman sia medyo matagal lang pick-up acceleration sa overtaking.pro konting bomba lang, sisibat na. sa nlex, average 120k di pa hataw, abot pa 140kplus pag may kakarerahan puno pako passengers. marami nga akong nalalampasang new sportivo variants. mas mabagal ba mga bagong xwind or ako lang yun?
June 14th, 2009 05:39 PM #213
It's both.
The Sportivo is relatively slower.
And yes, you have a mean speeding streak in you. 140 km/hr.....
By the way, be more prudent on your driving prowess esp. so if you have passengers. Racing in public roads does not really prove something worthy.
Drive safely.
- Feb 2009
- 11
June 24th, 2009 11:10 PM #215Guys sumubok ako ng rancho 5000 series panalo cya bigger shock di parin nawawala yung comfort parang stock pero stiffer so mas maganda sa cornering pag gusto nyo contact nyo lang ako
price range ng shocks nasa 4000 for the rear and 5k for the front.
IŽll post pictures of it when I have the time.
09177210000
June 25th, 2009 10:06 AM #216
Hi Guys,
I got an Isuzu Crosswind xuvi 2005, just recently I encountered this problem when you shift gear to reverse (ofcourse in fullstop) may griding sound and hirap ipasok sa reverse. Ano kaya problem nito, kinakabahan ako baka masira transmission ko.
Hope some can tell me what the problem is.
Thanks.
- Aug 2009
- 13
August 7th, 2009 03:20 PM #217Gud Day. Wuth regards to your problem, my experience is hindi lang sa reverse mahirap ipasok clutch, even in 1st 2nd, 3rd & 4th. Pinatingnan ko sa mekaniko, ini-adjust yung clutch. (i dont know yung adjustment na ginawa) Kaso, matigas tapakan after the adjustment. So tiningnan yung primary and secondary clutch. Nakita nung mekaniko na may leak yung secondary clutch kaya pinalitan yung secondary clutch assembly. Sabi sakin, kung konti lang leak, secondary clutch repair kit ang papalitan, pero yung sakin ay ang kailangan ay buong assembly. Ok naman after mapalitan. Yung repair kit ay P350. Yung buong assembly ay P550. Standard naman yun para sa 4JA1 na engine kaya pwedeng hindi na sa kasa bumili....
August 7th, 2009 09:24 PM #218
Sliding na ung clutch ko, according sa mechanic we need to replace the following.
- Pressure Plate
- Clutch Disk
- Release Bearing
any idea how much ung cost nito? thanks.
August 9th, 2009 02:15 PM #219
pards, need help about the head unit ng crosswing xuv 2004 model ko. ayaw kc mg-play ng cd. Is there any store you can recommend ng-aayos nito? thanks
August 9th, 2009 04:23 PM #220
The assumption that the vehicle runs on the road, the ECU is more than likely a match. Try cleaning...
***HELP*** iding problem
