Page 79 of 371 FirstFirst ... 296975767778798081828389129179 ... LastLast
Results 781 to 790 of 3710
    Feb 2005
    #781
    Quote Originally Posted by kafph2000 View Post
    Sir benz, do you have a diagram guide for disassembling the headlight?
    I believe I don't have but that should not be so difficult.... the tricky part is keeping it "air tight" when re-assembly for water or moist might leak in.
    May 2008
    #782
    Quote Originally Posted by Benzmizer View Post
    Simply said, a grounding kit is a safe and reliable way of creating a low resistance ground path for your car. The kit provides direct ground paths from battery negative to body, chassis, and specific engine components to give a noticeable improvement in electrical circulation. Reduced electrical “noise” can improve ECU signals and throttle response resulting in better performance and reduction in flat spots, and many more benefits associated with improved grounding.
    Oh, HIGH TENSION WIRES (aka HiTen) are different to a grounding kit. HiTen are only available on spark plug-equipped vehicles. These are how those look like:
    ... while a grounding kit looks like this:
    ahh ok ayun pala kaibahan nila thanks sir benz!!...
    Quote Originally Posted by kaioz View Post
    mga sir pano ba mag align ng headlight ng XUV 02, mejo mataas yung ilaw eh dami nag fflash sakin.
    also planning to replace headlight bulb ng crosswind xuv 02. bibilin ko osram nightbreaker. busted na yung left eye ni XUV eh
    medyo mahirap gawin yan...meron kasing pinipihit jan sa likod ng headlight na screw pang adjust ng headlight horizontally according to your liking...however, meron kang mapapansin jan sa housing ng headlight na percentage, nakalimutan ko na kung anong sinusukat non ehh...you can search online for tips on aligning headlamps, though hindi nila ine-explain kung para san yung %...
    May 2010
    #783
    mga sirs mag ask lang ako.. kelan ba due palitan ang clutch disk? 68k na kc odo ko.. hindi pa naman cya nag slide pero mas maganda na din yung sure.. and kailangan din bang palitan pati yung pressure plate at oil seal ba yun .. TIA mga gurus
    Feb 2005
    #784
    Quote Originally Posted by sportivonidave View Post
    Dalawa lang yan.... ganyan katibay ang ISUZU at ganyan ka kagaling gumamit ng Crosswind mo!
    Seriously, you need not have to replace any of what you mentioned unless necessary.
    Jun 2010
    #785
    Hi guys,
    Sa mga nagpalinis na ng nozzle, kamusta ang result? May improvement ba sa takbo ng makina at exhaust? My crosswind just reached 70k kms, and balak ko narin isabay sa oil change yung nozzle cleaning. Advisable ba? Thanks bros!
    May 2010
    #786
    ok thanks a lot sir benz..
    #787
    Your valuable help needed:
    i got a crosswind XL. it figured in a flood here in my province.
    I got it fixed except for the instrument panel (gas gauge, speedometer, etc.) which was busted - the temp and gas gauge needles are haywire, the odometer is busted back to "000000". Anybody know whats the best thing to do? Do i have to replace it with a brand new instrument panel assembly? If so, where can i buy except from the usual isuzu casa? magkano ba usually yon?
    I also want to lessen the loud engine sound. Parang Jeep. medyo hindi naman maingay tunog ng makina ng sportivo at ibang top of the line models. bakit ang ingay talaga ng XL.
    #788
    ANo ba ang brand ng evaporator ng crosswind? yung bugoy na aircon repair shop na pinagpaayusan ko dati pinalitan ng iba, di na ganun kalamig ever since.
    Feb 2005
    #789
    Quote Originally Posted by oliver1013 View Post
    Evaporator or Compressor?
    Apr 2008
    #790
    simple check up lang ung amin umabot ng 120k sa odo walang pinalitan.. nabenta na siya
Isuzu Crosswind Owners Thread [continued]
