Results 1,431 to 1,440 of 1770
May 23rd, 2010 09:31 AM #1431
That little knob you are referring is the chock --- yes, it'll temporarily solve the issue on low idle but SHOULD not be permanent. That is used when cold starts to help achieve the normal operating temp of the engine faster.
The recommended (normal) rpm should be:
without aircon/load - 700-750rpm
with aircon/load - 800rpm
With this, your 550rpm (without load/aircon) and 600rpm (with load/aircon) is considered low.
- Oct 2009
- 59
May 25th, 2010 12:23 AM #1432normal lang ba na puti ang usok ngcrosswind? kac napapansin ko pagumaga parang mausok siya pagstart ngengine at nakaidle kac usually bago ako aalis ngbahay 3 to 5 mins idle para uminit ang makina, then napinsan ko kanina pagtraffic at nakaidle nakikita ko ung reflection ng usok sa sidemirror kac naiilawan ngkasunod ko na sasakyan. normal ba ito sa xwind?
May 25th, 2010 12:23 PM #1433
Yung sa akin puti din usok pagstart sa umaga ganito na sya mula nung nabiling brand new. Yung medyo mausok nangyayari din ito sa sportivo ko kapag matagal tagal ko na hindi nilinisan yung exhaust kita din sa side mirror parang smoke screen hehehe. Binubugahan ko ng tubig mula sa hose pagkatapos non wala na masyadong usok sa idle or sa arangkada. Yung iba tinatapakan yung accellarator para matanggal lahat pati yung sa loob pero ako hindi na. Once a month ko lang ginagawa ito sir try nyo sir.
- Oct 2006
- 4
May 26th, 2010 01:09 PM #1434
http://i938.photobucket.com/albums/a...5262010911.jpg
Had a similar problem before. Ito yung ginawa namin sa idle up switch, naglagay lang ng rubber nakabalot dun sa "hook" kasi hindi na tumutukod sa idle control kapag humila yung idle up switch ng a/c. Crude but effective.
May 27th, 2010 10:11 AM #1435
May 30th, 2010 02:50 PM #1437
replaced my foglamps to dlaa it only cost me P1,100 pareho lang sya nung binebenta sa casa.. but casa price is P5K plus
May 30th, 2010 08:30 PM #1438
mga sir meron akong napansin na pag-full steer sa left may tumutunog na parang humahampas na bakal...neron na po bang nakaranas ng ganun...
May 30th, 2010 09:13 PM #1439
- Oct 2007
- 50
May 31st, 2010 03:12 AM #1440
Firefox browser - :wonder: may error kapag mag attached ako ng piktyur sa computer ko insert image...
Problems with viewing Tsikot on non-Chromium...
