Results 1 to 10 of 10
- Oct 2005
- 13
November 1st, 2007 06:07 PM #1Help mga Bro, malabo headlights ng Isuzu Bighorn ko. To those who have the same vehicle, had the same problem, pwede ko bang malaman kung anong modifications ang ginawa nyo?
1. Kung nagpalit kayo ng bulbs? What kind of bulb, its brand and wattage?
2. Kung nagpalit naman kayo ng relays? Ano ba ang rating ng relay na na-install nyo? Please help me, I'm having difficulty driving at night. Many Thanks. More power to all Tsikoteers.
November 1st, 2007 09:03 PM #2
RHD kase orientation ng headlights mo. the side of the road is dark but kawawa ang kasalubong dahil ang cutoff ng light output ng RHD headlights na sa incoming traffic.
BANNED BANNED BANNED
- 3,790
November 1st, 2007 09:10 PM #3Japan na RHD converted to LHD ba yan... then, you will need to change the lens na pang LHD. Magkaiba yung dalawa kasi.
November 1st, 2007 09:56 PM #4
i had a big horn before but didnt encounter this problem with the headlight. sir can you specify your problem, what do you mean mahina? So we can analyze more the problem and come up with the possible solution..
- Dec 2002
- 2,335
November 1st, 2007 10:30 PM #5maliwanag dati na lumabo? if this is the case then pa check mo lang wiring mo and you might need to replace the bulbs. Use OSRAM Silverstar. Stock wattage, +50% light output. Tama ung comments ni ARB and wildthing so dont try to increase wattage of the bulbs. Kawawa oncoming traffic. Solution for me before was I added Hella driving lamps. FF series. Malaki tulong. Meron na rin akong OEM na foglamps nun, PIAA.
- Oct 2005
- 13
November 3rd, 2007 04:29 PM #6
- Oct 2005
- 13
November 3rd, 2007 04:39 PM #7
November 3rd, 2007 05:05 PM #8
so was my bighorn i own before, but i didnt notice that it was not focused correctly on the road.. di masyado affected ang focus on the road even if it was originally rhd, kasi the lower portion of the headlight lens would be the same for lhd and rhd, only the cut off on the upper portion and different..
malabo siguro dahil:
- the lens.glass ay malabo na kaya malabo na buga ng ilaw or
- the bulbs are malabo na and need to be changed or
- the reflector of the headlights are tarnished na kaya malabo na ang buga?
anyway, i dont think its worth replacing with original brand new headlights bec this option would be expensive, if meron available, nor there would be available taiwan replacements.
so i agree with one suggestion here, buy those after market fog lamps to augment the headlights, gwapo pa tignan and not that expensive.. hope to be of help to you..
- Oct 2005
- 13
November 29th, 2007 08:00 PM #9
Moved some videos originally posted here to my other channel. Youtube does not allow same video in...
