Results 1 to 10 of 19
January 26th, 2009 09:24 AM #1
fellow tsikoteers.My hilander has this issue everytime pag cold start. u have to press the gas pedal para magtuloy ang start, if not mamamatay engine. pag nagstart na sya ng mga 2mins ok na dahil i can run sa slex ng mga 120km/hr wd no problem . i already did several troubleshooting:
idle is at 750-800rpm - so its not too low
injection pump was overhauled at betan calibration just last month
fuel filter was recently changed
i was reading through several posts and it seems that 4ja1 have no glowplugs, yun lang naiisip ko cause ng hirap pag cold start. pero may nabasa rin ako na may isang glow plug daw sa may injection pump yung ibang direct injection engines na walang standard glow plugs.
id appreciate some inputs from fellow tsikoteers and isuzu peeps.
January 26th, 2009 10:08 AM #2
Sir, matagal ba na redondo bago magstart? How is the idle once it fires? Mileage po?
January 27th, 2009 09:11 AM #3
sir one click lang start na, problem is pag nag start na idle nya is aangat ng mga 600rpm then bababa na until mamatay unless tapakan mo gas pedal. so ganun ginagawa ko mejo apak muna gas pedal ng mga 1 minute para uminit, after nun no problemo na. pag uminit na normal na idle nya at 750-800rpm. i've been doin some research and wala naman daw glow plugs ang hilander, so ano po nag tataas ng idle sa cold start? may temp sensor kaya sya? mileage is 91,000km.
January 27th, 2009 09:34 AM #4
sir wer r u from? kung malapit k lng dito sa laguna pde kita mrecomend sa friend ko n tgaisuzu pr matignan yng sskyan mo.
January 27th, 2009 10:35 AM #5
taga taguig po C5. pero nagwwrk ako dito sa alabang.taga saan sya sir?
January 27th, 2009 11:11 AM #7
January 28th, 2009 10:11 AM #8
seals are new dahil pinanood ko nung binuksan yung overhaul kit na may rubber seals at pinalit nila. napansin ko kaninang umaga na kahit na tatapakan ko yung gas pagkastart e after 1-2 seconds bababa rpm nya ng mga 200-250rpm then mag steady na dahil nakatapak ako sa pedal.
January 28th, 2009 10:14 AM #9
February 6th, 2009 11:35 PM #10
May idle controller yan. Puwede mong taasan muna idle at start, then ibaba mo na lang after mag-init. Im also from taguig c5 and may repair manual ako ng 4jA1.
katas nang public non-works and la ninya.
2020 Kia Sonet
