Results 1 to 19 of 19
    fellow tsikoteers.My hilander has this issue everytime pag cold start. u have to press the gas pedal para magtuloy ang start, if not mamamatay engine. pag nagstart na sya ng mga 2mins ok na dahil i can run sa slex ng mga 120km/hr wd no problem . i already did several troubleshooting:
    idle is at 750-800rpm - so its not too low
    injection pump was overhauled at betan calibration just last month
    fuel filter was recently changed
    i was reading through several posts and it seems that 4ja1 have no glowplugs, yun lang naiisip ko cause ng hirap pag cold start. pero may nabasa rin ako na may isang glow plug daw sa may injection pump yung ibang direct injection engines na walang standard glow plugs.
    id appreciate some inputs from fellow tsikoteers and isuzu peeps.
    Sir, matagal ba na redondo bago magstart? How is the idle once it fires? Mileage po?
    Quote Originally Posted by 4JGtootsie View Post
    sir one click lang start na, problem is pag nag start na idle nya is aangat ng mga 600rpm then bababa na until mamatay unless tapakan mo gas pedal. so ganun ginagawa ko mejo apak muna gas pedal ng mga 1 minute para uminit, after nun no problemo na. pag uminit na normal na idle nya at 750-800rpm. i've been doin some research and wala naman daw glow plugs ang hilander, so ano po nag tataas ng idle sa cold start? may temp sensor kaya sya? mileage is 91,000km.
    May 2007
    sir wer r u from? kung malapit k lng dito sa laguna pde kita mrecomend sa friend ko n tgaisuzu pr matignan yng sskyan mo.
    taga taguig po C5. pero nagwwrk ako dito sa alabang.taga saan sya sir?
    Quote Originally Posted by carlogt View Post
    Its possible that its air in the lines. Check clamps, hose, filter housing and filter and its installation. Possible din na initial pumping of the injection pump is poor because of worn oil seal, but since bagong calibrate pa lang i assume that its new.
    Let me do research on your engine then balitaan kita.
    4JGtootsie maraming salamat!!! mejo dead end na kse ko dito sa issue ko na to. tsk tsk
    seals are new dahil pinanood ko nung binuksan yung overhaul kit na may rubber seals at pinalit nila. napansin ko kaninang umaga na kahit na tatapakan ko yung gas pagkastart e after 1-2 seconds bababa rpm nya ng mga 200-250rpm then mag steady na dahil nakatapak ako sa pedal.
    di ko kasi alam ano nagcocontrol ng idle pag cold start since wala sya glow plugs. meron ba dapat linisin na idle up valve/controller? or temperature sensor ang 4ja1 na mkkdtct na malamig pa makina para taasan idle? how about yung throttle san ba yun lilinisin?
    May idle controller yan. Puwede mong taasan muna idle at start, then ibaba mo na lang after mag-init. Im also from taguig c5 and may repair manual ako ng 4jA1.
    colt45 sir soft copy ba yan baka pwede mo naman ako padalan ng copy sa email.
    Aug 2009
    sir umaga, ask ko lang po sana kung sana kayo sa laguna?
    malaki na din po kasi nauubos ko sa xtrm 2001 ko , mula ng mabili ko last may 19, until now pabalik balik po kasi sa mekaniko, sa bulacan ko pa po dinadala.
    wala po kasi ako kilala na mekaniko dito sa laguna.
    Thanks po!
    Feb 2006
    sir colt45,
    baka pwede po mkhingi ng soft kopya nung repair manual ng 4ja1 sir?pasend din sa email?
    aditanate*gmail.com
    dami thanx po
    Aug 2003
    ako rin. pwede humingi ng copy?
    Aug 2009
    colt, bro me pdf copy ka ng manual? pa send nman bro, mcd_dad*yahoo.com
    Tenx
    Guys having idle problem in the morning...... do you still have the problem? I had that problem also with my trooper and yung bayaw ko ang naka solve, pinag tsagaan lahat ng possible sira. He was able to detect the problem dun sa cylinder where you pump pag nauubusan ng diesel. The seal has leak kaya pumapasok ang hangin. I hope this help..... just sharing
Isuzu 4ja1 - startup idle issue
