Page 24 of 42 FirstFirst ... 1420212223242526272834 ... LastLast
Results 461 to 480 of 822
    Feb 2010
    #461
    Good day, Can anyone help me. Im buying a Isuzu Bighorn preferably 1997 up model the one with curves dashboard. I have ready budget for a worthy bighorn.
    May 2004
    #462
    Quote Originally Posted by s_quilicot View Post
    Guys, share ko lang. New shoes ng trooper ko.
    Tires: Mickey Thompson ATZ Baja radial LT265/75 (10ply) on 16x8 Dick Cepek DC-1 black/ AMS predator. (Sorry sa picture quality. Camphone lang kasi yan courtesy of bwiseat!
    Comments naman jan!
    SQ, pakilinaw ng konti hehehehe.
    Trade in your old shoes?
    #463
    Quote Originally Posted by niwde11 View Post
    Post ako bagong pics niwds!
    No. Walang value eh. Decoration nalang dito sa kwarto ko. hehehehe
    Feb 2010
    #464
    Im so thankful that i found this website, it is very helpful to me and im sure for others also...
    2 weeks ago, i went to manila from Leyte to find a trooper/bighorn and after few days of searching, i finally found my Bighorn 4jg2 matic. When i bought it, im aware that it has a few oil spill underneath the oil pan, then i decided to go to shell service bay to lift the car and check for that particular oil spill. Hindi nman tumatagas talaga pero nag drop talaga nang few, when i found out that it is just the hose of the turbo connecting to the crancase that is leaking, then we replace the hose tapos na wala na yung tagas. While im driving on my way to Leyte Land trip around 1,500++kms, the diesel is very economical when after few days after I arrived here, biglang maasksaya na sa diesel, then i found out that their is leak again in the hose na newly replaced in mnla. Im afraid baka nasira na turbo ko. Now, my car only top speed of 100kmh at nahirapan pa yun, diesel consumption is terrible. Pls. pls. I need help of the gurus here in tsikot specially to sir 4jgtotsie that im sure can advise me of what to do.
    Jul 2003
    #465
    Quote Originally Posted by yoydyey View Post
    Bro, check mo yung fuel metal hose from tank kasi sakin ganyan din nag rust na What I did I replace the metal hose with aluminum/bronze hose yung hindi kinakalawang. yun solve ang problem ko much better kung pabba mo yung fuel tank mo para madrain at malinisan.
    Feb 2010
    #466
    thank you sir, but its the oil hose of the turbo charger to crankcase ang nag leleak, does it affect of running performance of my car, coz it has a lot of pressure in it ryt?. My car only run 100kmh top speed and the diesel consumption is multiplied by 2. Pls pls.
    Feb 2010
    #467
    thank you sir, but its the oil hose from turbo charger to crankcase that is leaking, napaka sikip kc nang makina baka di gaano na tighten yung clamp, yan ang duda ko kc nakaka disturb talaga, my car only top speed of 100kmh and the diesel consumption is doubled. Pls. pls. any other views.
    Jul 2003
    #468
    Simple lang bro ang problem mo kung hose lang. Palitan mo ng magandang brand na hose at very good clamp ayus na problem mo.
    #469
    Try to tighten it first. Double banjo bolt yata yan na may cooper washer yan that serves as sealer. Its a tight space. Silipin mo from the right side wheel well tanggalin mo yung rubber half moon, kitang kita yan
    Feb 2010
    #470
    gud eve sa lahat, I just went to the mechanic at pina tighten ng mabuti yung clamp pero its all the same. They said maybe it is the injection pump or injector kc napaka usok at walang power ang makina ko. May kinalaman kaya ito sa pagka abnormal diesel consumption nito at sa walang power?
    Dec 2007
    #471
    Sir now that we have ruled-out the hose clamps area, try to check your air filter. i have learned that black smoke and lack of power could be caused by rich fuel and lack of air. baka clogged po air filter nyo, palinis or palitan nyo lang. hope this helps.
    Dec 2007
    #472
    add ko lang kasi di ko ata nasagot tanong nyo sir. yes may kinalaman ang fuel pump and injectors resulting to lack of power. Reason for suggesting air filter muna is mahal kasi calibration ng pump, baka simple at low cost lang ang solusyon sa problem. hope makatulong.
    Feb 2010
    #473
    Brothers,
    I think I need to have an a/c unit installed at the back, where do you think is the best place to have one done to my bighorn? How much do you think would it cost?
    Jul 2003
    #474
    Try blanking off your EGR valve read this link http://www.itocuk.co.uk/forums/viewt...ight=blank+egr
    #475
    Hi guys.
    Just want to share to you na yung ECM/ECU a.k.a computer box ng 4jx1 ko nasira nadin. 118k sa casa but I've got it repaired for only 15k.
    Feb 2010
    #476
    thanks sa lahat na nag reply sa problem ko, will go to shop this weekend to check my car. I will remember all ur advise. Balitaan ko nalang kayo.
    Feb 2010
    #477
    sir nap, blanking off the egr valve, can I just simple do it?
    Jul 2003
    #478
    oo bro madali lang kung gusto mo ipagawa mo nalang sa any gas station pagtanggal at pagkabit pero dapat meron kanang ready pang takip. meron nabibiling abestos sheet sa auto supply yun ang gamitin mo para madaling icut.
    Jun 2009
    #479
    Good evening, were planning to upgrade our 2002 Isuzu Crosswind XUV thru engine swapping, and ang plan namin is to buy an Isuzu Trooper Engine, to be specific, a 4JX1 engine mated to a Manual Tranny... Ok lang ba gawin ito? Need kasi namin advice about this, hindi kasi mabenta ang sasakyan, kaya i-upgrade nalang para bumilis, mahina naman ang turbo ng 4JA1, kaya I'm asking kung ok ba o hindi...
    #480
    Quote Originally Posted by 983264 View Post
    No. read first the problems of "4jx1" engine. second. finding a manual tranny for 4jx1 would be hard to find.
Big Horn/Trooper owners
