Hi guys,
Ano ang specs ng speakers ng 2010 Isuzu Alterra? Nasira kasi ang sa akin ang gusto kong bumili ng replacement.
Wala sa manual ang specs. I just want to know the size, ampere, wattage, and other relevant info.
Sabi sa akin ng taga Blade, 6.5" ang size nun. Tama ba? Kung ganun, pwede na kaya eto:
https://www.lazada.com.ph/products/h...mKqE4&search=1
I noticed that the clutch pedal is hard to press and there is growling noise when the vehicle is idle but the noise goes away when the clutch is pressed. LSA-M purchased June 2016, 56k odo, last casa pms at 25k, succeeding pms outside casa. Please help.
Sent from my ASUS_X018D using Tapatalk
Sana ma resolve ang issue sir with flushing ng fluid. Sir just in case anong clutch fluid gamit mo?
Napansin ko lang since nag pa pms ako outside casa hindi na malambot apakan clutch pedal
Mag1 dot 3 ginamit ko. Hindi kaya inadjust ng casa un push rod nyan?
Sent from my Redmi Note 8 Pro using Tapatalk
I mean outside casa pala un huling pms. Baka inadjust. Depende kasi talaga sa driver ang wear ng clutch.
Usually that growling noise is coming from the release bearing itself or contact between the release bearing and pressure plate finger, in some cases the clutch pressure spring or it's inner spline. You will can only confirm once you pull down the tranny. A good experience mechanic can spot it. But since naka pull down na better replace na lahat.
Same happened to my car although (non-Isuzu), same lang naman principle ng manual tranny.
Tnx much sir! Guys any shop that you can recommend where i can have my tranny fixed?
Got this dongle working with the stock headunit. Carplay is seamless. Need tinker a bit with android auto.
I used this dongle and just followed the instructions.
Apple Carplay / Android Auto USB dongle kit for Toyota Head Unit | Lazada PH
