Page 600 of 607 FirstFirst ... 500550590596597598599600601602603604 ... LastLast
Results 11,981 to 12,000 of 12125
    Quote Originally Posted by saluyet View Post
    SA advised me na pati shocks na din. He recommends bilstein. Any comments?
    it rides abit stiffer compared to the oem shocks. if you want the soft ride mag oem ka. if you want the slightly stiffer ride bilstein. heres an article about bilsteins replacements..
    Road Testing the Bilstein shock upgrade for Trailblazer | James Deakin
    #11982
    The Bilsteins are a lot stiffer vs stock bro. 5100's & B6's valving are digressive (great high velocity damping, too much low velocity damping)
    On the plus side, it corners with confidence and big bumps and dips are dismissed like they aren't there.
    But on smaller rough spots like rumble strips and uneven concrete roads you can really feel everything.
    I suggest you try out someone else's MUX with these shocks before you buy them.
    Jan 2013
    #11983
    The Bilsteins are a lot stiffer vs stock bro. 5100's & B6's valving are digressive (great high velocity damping, little to no low velocity damping)
    D you think these shocks will cure the mu-X's somewhat wallowy ride sir? Nag nnose dive din siya which is kind of annoying at times.
    Sent from my H8266 using Tapatalk
    #11984
    Quote Originally Posted by LancerA174A View Post
    Had to correct myself. Edited the post na. Too much low velocity damping.
    It will definitely remove the wallowy ride. And it'll handle a lot better. But in most cars I've driven/ridden with the same family/model (B6/5100) the ride on small undulations is so annoying specially at low speed I either have to fly through them or slow down to a crawl to make it bearable.
    I find most twin tube shocks have progressive damping and are easier to live with. You can slow down on bigger bumps or deeper ruts anyway. And on small undulations common on our roads you can maintain a decent speed while still being comfortable.
    Best test drive someone else's rig talaga before buying. Mahal din yang Bilstein.
    if you want to improve your suspension. youll have to go with kits from ironman 4x4. sila nag dedevelop talaga ng kits.
    yun iba kasi like ridemax, mix and match sila. unlike ironman 4x4 meron sila complete R&D for specific vehicles.
    Dec 2008
    #11986
    Thanks for the inputs sirs.
    Sep 2014
    #11987
    gawin nyo na lang kasi 40psi ang gulong ng MUX nya para hinde wallowy, it's wallowy coz 29psi ang nasa pinto, pag sinunod nyo yun masyado boaty and also less fuel-efficient . but the stock Bridgestone tires is max at 44psi.
    My rules is always minus 10%. of the max PSI, so 40 psi aka sa blue power.
    with my Santa Fe I , also do 40 psi kasi 44 psi din max sabi sa gulong weird coz it's only 235/65/R17
    and my wildtrak I also do 40 PSI, coz even of 265/60/R18 Bridgestone sya as compared to my 255/60/R18 Bridgestone MUX, pareho sila max 44psi
    My Santa Fe still uses the stock springs from year 2007, never pa nasira , and I just follow that tire rule, less than 10%
    pag ang tires optimal ang laman ng hangin, less strain sa suspension coz the tires absorbs the imperfections of the roads. it acts as a backup suspension, yun goma. I learned that somewhere in the net some 5 years ago
    mas mura naman gulong noh, kaysa suspension parts.
    Jan 2008
    #11988
    Agree ako sa mas mataas na tire pressure para mawala o mabawasan un wallowy ride. 35psi naman ako.
    Un kyb skorched4 shocks ok kaya para sa mux?
    Sent from my Redmi Note 5 using Tapatalk
    Aug 2008
    #11989
    Ako 35 psi lahat ng gulong. Early morning psi yun ha. Pero I observe sa tpms na umaakyat hanggang 39 psi lalo na kapag long drive at mainit. Sayo kung cold tire psi mo mo yan 40, eh baka umabot ka ng 44psi na sinsabi Mong max
    Sep 2014
    #11990
    Quote Originally Posted by jigeloh View Post
    Ang napansin ko kasi dyan sa mga pahanginan sa gas station like for example sa shell , if you load like 40 psi , check after 3 days and your tire pressure is ranging 38 to 39 psi.
    It’s either the pump is miscalibrated or yun hangin mismo nila is substandard. I dont load nitrogen kasi eh. One observation ko lang if sa ok na vulcaniizing shop ka nag pahangin consistent ang 40 psi for like 2 weeks or so. So malamang may impurities ang mga gas stations, well what can we expect libre, saka kung sino-sino lang naghahangin dun
    I dont have TPMS in my cars, pero I check the tires everytime I leave, after years of doing it, ma train naman eyes mo as well as konting pindot if your tires are in good shape, basta you are parked in a flat pavement like for example mall or condo parking.
    Yun kasi 35 psi , im not comofrtsble with it, although 35 psi is the most comfortsble, kumbaga para ka naupo sa cushy sofa vs sa 40 pai na sofa na may thin layer lang ng cushion
    So there you have it, pag ultra comfortable na ang car sa kin, thats the time pahangin na ako. Besides you ll never know when you have 4 to 7 passengers, so better be laging handa. Those extra weight can exact a great toll sa suspension pag sobra baba psi.
    Jan 2008
    #11991
    Ako palaging handa. May HD portable compressor sa utility box. Di ako umaasa jan sa gas stations.
    Sep 2014
    #11992
    Quote Originally Posted by kkreuk18 View Post
    Ang problema kasi dyan sa mga portable compressor is you need to get the most wxpensive ones, baka tipong tig 5k na US brand just to inflate the massive tires of a SUV.
    Yun mga nabibile dyan sa Concorde / Blade na tig 800 - 1200, kelangan bantayan mo kasi para yun motor nila yun katulad sa vacuum cleaner na binebenta sa harap ng Ace Hardware na may na naka mic pa minsan,
    Leave it on for 2 minutes, makita mo nag melt na yun plastic lol., kasi overheat na yun motor
    P800 inflator syempre may tubo pa Blade dyan, maybe 100% markup so P400 import cost nila, magkano na lang materyales na ginamit ng made in china dun lol . And then i depend mo sa brdigedtones suv tires na madalas 12k up
    ang problema naman sa mga Us brands na lets say nakuha mo sa Subic duty free, ang ganda ng kaha, stateside, pero yun pala same made in china motor din nasa loob lol
    Jan 2013
    #11993
    Finally replaced the front passenger door switch, nakakainis parang Christmas light yung door ajar pag umaandar patay sindi.
    Also looking for a dashboard clip kaso wala din daw stock pati planta.
    Jan 2008
    #11994
    Tig 2.4k sa ace un binili ko pero nabili ko sa lazada ng 1.5k. Metal body naman. Max 10mins na direcho andar, tapos pahinga ng 5mins. From 20psi mga 5mins para maabot un 30psi
    #11995
    ako naman, sa gas station ako uma-asa for my regular re-inflating.
    i use my portable inflator for emergencies and/or when the gas station inflator isn't available.
    ...hirap mag kabit at mag tanggal ng inflator, 'no!
    using the inflator sorta lengthens the life... lubrication is one concern noh?
    Jan 2008
    #11997
    Madali lang naman. Pero mas madali sempre un sa gas station. Pag nasa bahay naman ako, mabilis lang. Pagaganahin ko lang un air compressor ko. Saglit lang
    Sep 2014
    #11998
    Kung minsan sarap din panoorin MuX look alike mo in the wild hihi, though i wouldnf do this to mine , 1st reason , it’s 4x2, 2nd, ill will never do it talaga. Pang city driving lang talaga sakin para humaba buhay
    But this is pleasant to watch
    #11999
    * OB,
    Nood ka sa youtube ng 4WD Action Channel.
    Yong isa doon naka DMAX.
    Yakang-yaka mga hardcore trails.
    Sep 2014
    #12000
    sige nga thanks. lately, naghahanap ako ng mga mapanood sa YT
All New Isuzu MU-X // Alterra Next Generation
