Page 596 of 607 FirstFirst ... 496546586592593594595596597598599600606 ... LastLast
Results 11,901 to 11,920 of 12125
    Jan 2013
    #11901
    Quote Originally Posted by nowitzki41 View Post
    Mga sir, how many months/years may warranty yung DRLs? Busted na kasi yung 1.. Thanks!
    Sent from my LG-H860 using Tapatalk
    I think it should still be covered, kami naman before may leak yung right reverse lamp kaya pinalitan, madami na daw nagpa warranty sa unang batch ng units, though may isa dito sa amin naging green na yung reverse lamp niya sa lumot siguro, di na niya napapalitan.
    So far our unit's DLAA aftermarket DRL works fine since installed in 2016, I like the warm-ish white output compared to other brands.
    Sent from my E6683 using Tapatalk
    Dec 2014
    #11902
    Quote Originally Posted by LancerA174A View Post
    Hopefully covered pa nga ng warranty. Badtrip lang is the hassle of going to the dealer and yung oras na masasayang. Thanks sir
    Jan 2013
    #11903
    You can try calling them first sir just to be sure, ang mahal pala ng OEM DRL, umaabot ng 18K per pair, that's without the harness pa yata.
    Jan 2008
    #11904
    Update: After 3 full tanks of V-Power, the loose metal/clattery noise is still there. Might have to check with the dealer for proper diagnosis. Ang pangit lang talaga pakinggan.
    [emoji25]
    Baka kailangan na iadjust ang valve clearance
    Sent from my Redmi Note 5 using Tapatalk
    Jan 2013
    #11905
    Quote Originally Posted by kkreuk18 View Post
    Siguro nga sir, kasi every after PMS eh mas pino siya tumakbo pero after nung 75K Km baka di nila na-adjust.
    Maisabay na din yung tumutulong langis sa loob ng cabin sa ilalim ng steering wheel, not sure if its the power steering fluid.
    Btw, may naririnig din ba kayong squeaking noise sa loob ng dashboard? Parang styro na nagrrub, sumasabay din sa vibration ng engine.
    Sent from my H8266 using Tapatalk
    Jan 2008
    #11906
    Matagal na din akong di nagpapacasa. 20k km un last. Nasa 89k km na din un sa kin. Ang basis ko kung ok pa un tunog ay un coworker ko na low mileage un mux nya, same kami na 2.5 engine pero 2018 nya nabili. Wala pang 10k km ang mileage. Magkasing tunog pa naman un makina namin. Every 12-15k km ako magchange oil, delo sports 5w40 at amsoil 5w40 ang gamit ko mula nung mag 50k km.
    Cabin noise wala pa din naman. Di kaya brake fluid un tumutulo malapit sa steering column?
    Feb 2016
    #11907
    Sir, san ka nagpa PMS outside casa?
    Jan 2008
    #11908
    Sa garahe lang namin. Pag light pms ako lang, pag heavy katulong ko si erpat. Si erpat talaga mekaniko. Basic lang naman un oil change, palit ng mga filters at brake cleaning
    Feb 2016
    #11909
    Thanks sir. Buti u have a mech avail sa family. Goos for u sir.
    Jan 2008
    #11910
    Quote Originally Posted by rhizom3 View Post
    Buti na nga lang marunong ang tatay ko. Madami naman reputable shops. Ayoko sa casa, nung nakita ko un grease na ginagamit para sa wheel bearing nadismaya ako
    Dec 2015
    #11911
    My ride is LSA-MT acquired June 2016. I noticed that the reverse sensor is emitting continous sound when i put the gear in reverse even when there is no obstruction at the back. After 25k mileage PMS done sa casa, PMS is done outside na. Current mileage is 47k na.
    Sent from my ASUS_X018D using Tapatalk
    Jan 2008
    #11912
    Quote Originally Posted by Rob*143 View Post
    Ganun din un sa kin. Un reverse parking sensor ang sira. Parang 2.4k yan kay winterpine. Di ko lang mabigyan ng time para umorder
    Dec 2015
    #11913
    Sir dba cover ng warranty yun!
    Dec 2015
    #11914
    Sir dba cover ng warranty yun?
    Aug 2009
    #11915
    Grounded yan. Covered ng warranty.
    Saakin was replaced by Gencars last october ata..
    September ko sinabi yung issue during my PMS then october nila kinabit kasi inorder pa yung body-colored sensor..
    Dec 2015
    #11916
    Maraming salamat sa info sir!
    Jan 2013
    #11917
    Ah I see, ano kaya problem sir if brake fluid ang tumutulo sa may pedal?
    #11918
    Busted brake master
    Jan 2013
    #11919
    Quote Originally Posted by jvnj View Post
    Busted brake master
    Ah I see, I remember instances when I hear a tick sound when the brake pedal was depressed. Hindi naman po continuous yung leak, siguro mga 2-3 times ko lang siya napansin sabay linis na lang ng matting.
    bro kung meron brake fluid leak. have it addressed fast. brake fluid is highly corrosive. baka mag kalawang mga malagyan ng brake fluid. mura lng brake master.
All New Isuzu MU-X // Alterra Next Generation
