Results 11 to 20 of 32
December 22nd, 2016 09:01 AM #11
Better buy the horns as take out then let Jemson (near Sogo) install it. If sa shop ipapagawa, just make sure na maayos yung magkaka-ziptie ng wires para hindi masyado makalat tignan sa engine bay.
No effect sa electrical system ang relay. In fact mas better pa nga yan kasi sa battery na mismo kukunin yung power ng battery. Wala pa akong naririnig na issue with casa with regards to an installation of aftermarket horn na hindi sila ang nag-install.
December 22nd, 2016 10:28 AM #12
December 22nd, 2016 10:30 AM #13
nope. actually, the relay helps your electrical system in current distribution. instead of the horn getting the power directly from the battery, the relay acts as a switch.
Got from Google:
Relays in general are used to enable a low amperage circuit to switch on or off a higher amperage circuit, like turning on your headlights. If you were to try and directly hook up your headlights to the headlight switch you would exceed the amperage rating of the switch, melt wires, and risk an electrical fire. Relays are also used to switch multiple things at the same time using one output. A single output connected to multiple relays will allow you to open continuity and/or close continuity simultaneously, for example turning on your radio while the antenna extends.
January 3rd, 2017 10:05 AM #15
January 4th, 2017 11:57 AM #18
800 lang benta ko sa am80. Masyadong mura yata benta ko haha
January 4th, 2017 10:55 PM #19
Iba pa b yun AM80 sa AM80S (ito yun old unit ko installed sa xwind ko.)
san shop mo
Sent from my SM-J700H using Tsikot Forums mobile app
January 12th, 2017 04:26 PM #20
P630.00 lamang yung FIAMM AM80SX dito sa amin...
red and white carton packaging. 2 pcs ng horn, 1 pc relay, bracket.
tapos nakadikit lang yung sabi "Designed and Manufactured by .....etc....Italy" .
japeyks???
any car can handle navigating to Baguio basta nasa condition. kahit nga trike pwede din hehehe....
2023 Ford Everest Owners Thread
