Page 1 of 2 12 LastLast
Results 1 to 20 of 32
    Hi sirs. I plan to change the stock horn of my dmax lt. Looking at piaa super bass horn.
    A. Any comment on the product?
    B. I don't know exactly where it will be installed? Any idea?
    Thank you sirs
    Sent from my SM-P600 using Tsikot Forums mobile app
    Aug 2009
    Quote Originally Posted by tomtom View Post
    Been using it for a year na sobrang babad sa busina especially mga motorcycle and jeep na saan saan nagbababa.. Medyo mahina compared sa Europa but nakakabastos parin pakinggan. You'll need to put a relay, a thick wiring and good fuse para lumabas yung ganda ng PIAA.
    Import Elementz in G. Araneta. It will cost you around 2700 total with new wiring connection.
    Thank you sirs
    Quote Originally Posted by Sleepcare View Post
    Thanks for the reply sir.
    Where exactly under the hood is the best place to install it? where did you place yours under the hood? Right behind the grills?
    Ive been looking for the place where the stock horns are placed but can't locate it.
    Salamat ulit
    i just had my horn upgraded to FIAMMS.
    pag nasa loob ka ng oto, it sounds soft, pero pag nasa labas ka, nakakaasar ang tunog.
    it was installed behind the grille, in front of the radiators, nakayuko to avoid it being wet pag nagpapa carwash.
    i had a relay installed.
    Aug 2009
    Quote Originally Posted by 1D4LV View Post
    My first horn change was actually Fiamm AM80. OEM ng ford expedition and bmw yan noon. May nabusinahan akong jeep before kasi bigla nagbaba ng pasehero tapos binato ako ng wet tissue ng isang passenger. Ganyan ako katuwa sa Fiamm but changed it to PIAA kasi nararamdaman kong medyo nanghihingalo na but still very happy. I would purchase one again the in the future.
    If may relay, will it not have an effect sa electrical ng sasakyan. I own a 2yr old dmax sir. Pasensya na tanong. Newbie here. Salamat
    nope. actually, the relay helps your electrical system in current distribution. instead of the horn getting the power directly from the battery, the relay acts as a switch.
    Got from Google:
    Relays in general are used to enable a low amperage circuit to switch on or off a higher amperage circuit, like turning on your headlights. If you were to try and directly hook up your headlights to the headlight switch you would exceed the amperage rating of the switch, melt wires, and risk an electrical fire. Relays are also used to switch multiple things at the same time using one output. A single output connected to multiple relays will allow you to open continuity and/or close continuity simultaneously, for example turning on your radio while the antenna extends.
    Aug 2009
    Salamat ulit
    Usually sa Isuzu it's behind the grille. Kung wala sa grille, try to look behind the bumper.
    Maganda nga Fiamm AM80. Hindi pa sobrang mahal. Didnt know na OEM ito before ng BMW and Ford
    Aug 2009
    If you'll check the 99' Expedition and early 00' BMW, it had Fiamm as its OEM horn.
    yup. the one that i got is an AM80. sulit na sulit.
    How much am80
    Sent from my SM-J700H using Tsikot Forums mobile app
    Aug 2009
    Quote Originally Posted by x-wind View Post
    How much am80
    Currently 1200 na ang Fiamm AM80. Dati nasa 900 lang 3 years ago..
    How much am80
    yup. got it at 1.2k. Motortown Alabang.
    Any tip that i should kniw if ipapakabit ko sa banawe yung horn?
    Aug 2009
    Better buy the horns as take out then let Jemson (near Sogo) install it. If sa shop ipapagawa, just make sure na maayos yung magkaka-ziptie ng wires para hindi masyado makalat tignan sa engine bay.
    No effect sa electrical system ang relay. In fact mas better pa nga yan kasi sa battery na mismo kukunin yung power ng battery. Wala pa akong naririnig na issue with casa with regards to an installation of aftermarket horn na hindi sila ang nag-install.
    Free installation na rin ba?
    Sent from my SM-G610Y using Tapatalk
    800 lang benta ko sa am80. Masyadong mura yata benta ko haha
    Iba pa b yun AM80 sa AM80S (ito yun old unit ko installed sa xwind ko.)
    san shop mo
    May 2009
    P630.00 lamang yung FIAMM AM80SX dito sa amin...
    red and white carton packaging. 2 pcs ng horn, 1 pc relay, bracket.
    tapos nakadikit lang yung sabi "Designed and Manufactured by .....etc....Italy" .
    japeyks???
Air Horn
