Results 1 to 19 of 19
    Dec 2002
    Guys,
    Finally had the Besco 10w30 oil sample tested at a laboratory. Test results as follows, using same ASTM standards as other oils:
    viscosity at 40C : 64.77
    Viscosity at 100C: 9.89
    TBN : 14.2
    IMO, this is closer to a 5w30 oil but with very high TBN, which is necessary given the high sulfur content of our diesel fuel. I think Petron's synth, all terrain 5w30, will be a viable alternative for our 4JX-1 engines. The 5w30 synth has viscosity of 74.3 at 40C, 12.06 at 100C, TBN of 16- even better than Besco! :D
    I'm planning to test used samples of the 5w30 synth oil to see if i can extend drain intervals over the usual 5Tkm.
    Has anyone been using Petron's all terrain 5w30 in their 4JX1 trooper engines? Hope you find oil test useful.
    Thanks for the info...
    Sa filter, what replacement brand you're using now?
    Dec 2002
    redhorse,
    Still using isuzu oem oil filters due to warranty constraints. My friend has used the "Vic" replacement for the primary oil filter without any problems.
    I'm using the "Vic" replacement for the air filter, same size and no dust problem in the intake hose.
    What oil are you using now?
    besco, still.
    Right now DIY na ako sa change oil for Fuego, next Trooper.
    Thanks for the info. :DThanks for the info. :D
    Bought yesterday 8 liters of Petron's All Terrain 5w 30 diesel oil, anyone used this on trooper?
    Baka gamitin ko ito bukas pag sinipag ako uli na mag DIY, change oil this time. I have with me now the Oil and Fuel filters, both isuzu original.
    Dec 2002
    Redhorse,
    I've been using Petron's 5w30 since Dec. Engine feels smoother running at 140kph on star tollway. Start-up on cold mornings about the same, 2 sec crank. Not much smoke from exhaust, no less than Besco. Other friends using the oil in their troopers have no complaints.
    Are you changing both filters? Plan to try "Vic" oil filters on my next oil change.
    How much did you get your oil? Bought it last dec for P225/ liter but think it increased this jan.
    Jackaroo,
    Wow, sayang, its +15 pesos now per liter.
    Thanks for the reply.
  9. #9
    Jackaroo: The test results are very helpful. How much is the Petron All Terrain? I've been using VIC sa ibang car ko before and even up to now on my Honda Civic HB but in my Big Horn orig Isuzu pa rin ako which is around Php 800. Yung VIC around Php 480. 4JG2 engine ko. 402 ata yung oil filter. Anong VIC part No na gamit ng 4JX1? OK yung info mo coz I've been reading so many threads on this CD oil that Isuzu is recommending. May guarantee waiver sa Trooper pag ibang oil ginamit di ba? Sa last PMS ko I used orig oil filter, air filter and replacement fuel filter. Sa WALCO Banawe ko binili.
    Recomended rin ang 15W40 sa Diesel engines. :wink:
    Dec 2002
    garyq,
    The last time i asked, Petron all terrain 5w30 was selling at P235/L.
    I can use Vic part no C524 for primary filter which is about P175. Just list your orig isuzu oil filter part no and i'll check what Vic part no is compatible.
    Where is Walco, Banawe? Do they carry isuzu parts at prices below that of casa?
    change oil: (corrections are welcome)
    new oil filter was half-filled with oil before installation.
    New oil was poured in about 10 hours.
    cranked the engine four times, (30-second interval was observed) before finally starting the engine, normally as I would.
    Observations:
    the oil pressure gauge is less than the half-way mark as it was in besco during idle.
    The engine starts faster, even in these cold early morning weather
    Dec 2002
    redhorse,
    How do you crank the engine without starting it?
    After i change oil, the engine starts on the first crank but stops due to low oil pressure. It then runs normally on the second start.
    My oil pressure is at halfway mark when the engine is cold and idling then drops to less than half after the engine oil has warmed up.
    Jackaroo,
    it's similar to a failed start, by not going all the way (with all the lights on at the instrument panel, and a lighter twist, just once, then return). On the 5th, its like starting a fuego. But the next day and thereafter, I resumed to the way I start its engine.
    May 2016
    Whats the difference between 5w40, 5w30 and the Phoenix Zoelo Extreme 15w40 (CI-4/SL)
    the one that i'm using now, i was given a free sample of Seaoil Extreme Mako 5w40 with BlueSynth Tech, it's my first time to use fully synthetic oil, thanks for the reply
    Mar 2016
    Quote Originally Posted by MAD5267 View Post
    I just sold my trooper, In 10 years of having it didn't gave me major problem. It clocked 225,000KM when I let it go. I used 10w30 / 5w30 Besco or Royal purple. Dont ever use 15w40, it's too thick for crdi engine, it will damage your injector in the long run.
    Dec 2010
    Hi rod 13 - I have a 2013 trooper, and have been using Besco 10w30 oil. Recently tried using isuzu's 10w30 (econo) oil, and have not experienced any problems. Any comment on this oil type?
    Also, what would be the best interval to change RPS as part of normal preventive maintenance? I also need advise on my turbo charger! as it se ms to leak oil(?) [_ thanks, edvizc. ....QUOTE=rod13;2727076]I just sold my trooper, In 10 years of having it didn't gave me major problem. It clocked 225,000KM when I let it go. I used 10w30 / 5w30 Besco or Royal purple. Dont ever use 15w40, it's too thick for crdi engine, it will damage your injector in the long run.[/QUOTE]
    May 2017
    Quote Originally Posted by edvizc View Post
    [/QUOTE]
    Sir 15w-40 oil WILL NOT DAMAGE DIESEL injectors on crdi engines especially the 3.0ltr engine.
    What damages inje8ctors is low quality fuel, failure to replace fuel filters when needed.
    If 15w-40 oil damages injectors then almost all dmaxes in Australia would have had issues by now as many have passed the 200k mileage with no issues and still using 15w-40 oil.
    Isuzu oil Besco 10w-30 is similar to 15w-40 ok.when it comes to heat and performance that's why it does not suggest any other 10w-30 oil aside from Besco. All the rest it suggests in manuel are 15w-40 oil and all are mineral oils.not semi or fully synthetic.
    In fact the new Delo 400mgx 15w-40 is better than some semi synthetic oils and it's mineral oil.
    Some prefer 10w-30, 5w-40 or 15w-40 All these weights were tested on crdi engines and never was mention of damage to injectors especially in modern Direct fuel injection diesels.
    Besco brand is a great oil but still not the best compared to some other brands.
    If you find any info concerning 15w-40 damaging fuel injectors please post it.
    God bless you
    Jan 2008
    Quote Originally Posted by jackaroo View Post
    Guys,
    TBN : 14.2
    For my Alterra with 40k mileage, I use Mobil Delvac 5w 40. It sounds like new :-)
Trooper's Besco 10w30 lab test results
