Results 11 to 19 of 19
Tsikot Member Rank 3
- Dec 2002
- 636
January 25th, 2003 01:12 AM #11garyq,
How much is the Petron All Terrain?
Anong VIC part No na gamit ng 4JX1?
Where is Walco, Banawe? Do they carry isuzu parts at prices below that of casa?
Tsikot Member Rank 5
- 3,144
January 25th, 2003 10:31 AM #12change oil: (corrections are welcome)
new oil filter was half-filled with oil before installation.
New oil was poured in about 10 hours.
cranked the engine four times, (30-second interval was observed) before finally starting the engine, normally as I would.
Observations:
the oil pressure gauge is less than the half-way mark as it was in besco during idle.
The engine starts faster, even in these cold early morning weather
- Dec 2002
- 636
January 26th, 2003 07:20 AM #13redhorse,
How do you crank the engine without starting it?
After i change oil, the engine starts on the first crank but stops due to low oil pressure. It then runs normally on the second start.
My oil pressure is at halfway mark when the engine is cold and idling then drops to less than half after the engine oil has warmed up.
- 3,144
January 27th, 2003 05:36 PM #14Jackaroo,
it's similar to a failed start, by not going all the way (with all the lights on at the instrument panel, and a lighter twist, just once, then return). On the 5th, its like starting a fuego. But the next day and thereafter, I resumed to the way I start its engine.
- May 2016
- 1
May 14th, 2016 03:24 PM #15Whats the difference between 5w40, 5w30 and the Phoenix Zoelo Extreme 15w40 (CI-4/SL)
the one that i'm using now, i was given a free sample of Seaoil Extreme Mako 5w40 with BlueSynth Tech, it's my first time to use fully synthetic oil, thanks for the reply
- Mar 2016
- 12
May 19th, 2016 11:30 AM #16
- Dec 2010
- 2
August 1st, 2016 02:10 PM #17Hi rod 13 - I have a 2013 trooper, and have been using Besco 10w30 oil. Recently tried using isuzu's 10w30 (econo) oil, and have not experienced any problems. Any comment on this oil type?
Also, what would be the best interval to change RPS as part of normal preventive maintenance? I also need advise on my turbo charger! as it se ms to leak oil(?) [_ thanks, edvizc. ....QUOTE=rod13;2727076]I just sold my trooper, In 10 years of having it didn't gave me major problem. It clocked 225,000KM when I let it go. I used 10w30 / 5w30 Besco or Royal purple. Dont ever use 15w40, it's too thick for crdi engine, it will damage your injector in the long run.[/QUOTE]
- Jan 2008
- 169
September 1st, 2016 10:31 PM #18
- May 2017
- 18
January 25th, 2018 02:54 PM #19[/QUOTE]
Sir 15w-40 oil WILL NOT DAMAGE DIESEL injectors on crdi engines especially the 3.0ltr engine.
What damages inje8ctors is low quality fuel, failure to replace fuel filters when needed.
If 15w-40 oil damages injectors then almost all dmaxes in Australia would have had issues by now as many have passed the 200k mileage with no issues and still using 15w-40 oil.
Isuzu oil Besco 10w-30 is similar to 15w-40 ok.when it comes to heat and performance that's why it does not suggest any other 10w-30 oil aside from Besco. All the rest it suggests in manuel are 15w-40 oil and all are mineral oils.not semi or fully synthetic.
In fact the new Delo 400mgx 15w-40 is better than some semi synthetic oils and it's mineral oil.
Some prefer 10w-30, 5w-40 or 15w-40 All these weights were tested on crdi engines and never was mention of damage to injectors especially in modern Direct fuel injection diesels.
Besco brand is a great oil but still not the best compared to some other brands.
If you find any info concerning 15w-40 damaging fuel injectors please post it.
God bless you
Yung sa full record documentation nyo po, sa service manual ng CASA nyo po ba nirerecord self PMS...
Suzuki JIMNY [merged threads]
