Results 211 to 220 of 224
- Dec 2016
- 6
February 12th, 2017 10:41 AM #211pinalinis ko na ang starter sir and it runs like new again.. yun lang pala ang problem.. ruled out ang battery issues kasi brandnew siya tapos no drain at maganda karga ng alternator.. salamat po sa inputs
starter lang pala sir, after ng cleaning eh parang bago yung starting nya.. thanks sir sa input nyo
- Aug 2017
- 29
December 17th, 2017 06:55 AM #212Paano nga po ba pabilisin si crosswind (xto 2001)? And minsan pala pag nasa 3rd and 4th gear ako at medyo mababa c rpm eh may mahinang kadyot sya..bagong linis naman yung injection pump,pati tank..bago din ung fuel filter..bagong linis din sedimentor..
Sent from my CAM-L21 using Tsikot Forums mobile app
- Aug 2017
- 29
April 2nd, 2018 11:54 AM #213Problem solved..nagtono lang ng injector..lakas na ngaun hatak..wala na din kadyot.. tinaasan din nya yung menor at yung idle speed pag aircon on..di ko nagustuhan kasi feeling ko malakas sa diesel pag ganon. nagbasa ako na manual sobra sobra sa recommended na rpm speed.kaya binalik ko sa tamang timpla ung idle..ok na sya ngayon.
- Nov 2017
- 1,748
April 2nd, 2018 01:53 PM #214
April 2nd, 2018 01:58 PM #215
- Aug 2017
- 29
April 2nd, 2018 10:35 PM #216Di ginalaw nung tumingin yung nozzles.wala naman daw kasi black smokes na lumalabas.pag nag hard accelerate lang sya nagiging visible na may smoke..
*maxpedition
Yes,matibay talaga mga isuzu..ako din alaga sa change oil,di pa din na overhaul *340k kms as per odo..dun naman kasi buhay ng makina natin..next project ko naman pag nakaipon ay ipacheck ang pang ilalim.
- Nov 2017
- 1,748
April 2nd, 2018 10:52 PM #217
April 2nd, 2018 10:56 PM #218
- Aug 2017
- 29
April 19th, 2018 07:24 PM #219Di naman nya chineck yung nozzles eh. Kasi d nga naman sya mausok sir..saan pala nakikita yung egr na yun sa mga xto models?hinahanap ko nga din yun eh.
- Jun 2008
- 1,741
April 20th, 2018 12:25 AM #220Xto 4JAI engine? Wala naman ako nakita na egr valve sa 4JA1. Egr valve sa euro 3 - 4 diesel engine meron.
Sent from my NX549J using Tapatalk
Are mandatory seatbelts, and minimum brightness standards for exterior lighting also woke elements?
Carbon fiber hood
