Page 4 of 4 FirstFirst 1234
Results 61 to 72 of 72
    Jul 2016
    #61
    Dapat ko nang malinis engine ko kasi super dumi na. I know hindi siya kaya ng towel or spray method, so may alam ba kayong marunong mag engine wash sa may South area?
    #62
    My car got an engine wash from the casa for the first time on its 6th yr. Luckily they did a good job naman.
    Mar 2004
    #63
    Quote Originally Posted by Mree View Post
    If you want to be safe, have engine detailed instead of engine wash.
    Jun 2016
    #64
    Quote Originally Posted by rodetor View Post
    I only seldom use Trim Detailer or Engine Dressing, or what you may call it, after I had it engine washed. Minsan, di ko na nilalagyan, pakapit lang kasi ng alikabok. Kaya di na ako naglalagay.
    Starmobile Up+
    Dapat water-based ang dressing. Pag oil-based, yun ang kapitin ng dumi. Hehe.
    Oct 2009
    #65
    basta ako tide ultra lang ,kapag makapal ung lagis gumagamit din ako ng kerosine after kerosine tide ulit na may kaunting tubig 30%tide 70% tubig.gamit ng paint brush. after ng tubig na may tide ,pure water naman para pang banlaw i brush mo nalang din.may nabibili sa national bookstore ung mahabang paint brush ginagamit ng mga painter,,saka part by part .hindi naman kailangang mabilisan ang pag engine wash kung DIY lang..para iwas aberya..
    Aug 2012
    #66
    Tide Ultra.. Hindi lang pang-labada, pang-makina pa.
    Sent from my D5833 using Tapatalk
    #67
    I just use Gunk Foam degreaser. It really clean the engine fast. After 10 minutes tapos na ang engine cleaning. I just let it dry before using it.
    Meron Sa mga talyer sabihin niyo lang. Gaas pa wash Nila tapos yun water after. Meron sila attachment lagayan ng gaas and water para doon Sa air compressor Nila after hanginan pa Nila.
    #69
    the only part i cover is the alternator and ecu. then i just use a very strong mix of joy, spray on, wait a few minutes, then rinse off using a pressure washer. syempre common sense, pag nakita mong electrical e di don't spray directly especially sa mga terminals. masisira lang electricals mo pag nababad, like kung direct yung spray mo ng water at pasukin sa loob, or flooded. for battery terminals i brush with soap (joy), then rinse with ordinary water, then coat with silicone electrical grease or spray.
    gusto mo water proof ang electrical connectors and terminals? diy, lagyan mo ng electrical heat shrink tubes. i started doing this on my bt50 before but never finished.
    last month i got refused at the car wash again! pagkakita pa lang nila sa malagkit na putik they waved me away hahaha! inabot ako 3 hours magtanggal ng putik
    #70
    Usually ayaw nga ng mga carwash sa mga maputik/galing offroad hehe
    Sep 2014
    #71
    Graduate na ako sa engine wash and detailing, I did 5 cars for the entire july. Dami ko fears na na surpass.
    For instance, umusok ang maitim ang engine ko and my aircon clutch got shorted. I though i broke my car, pero umayos din
    Engine cleaning is an art.
    Btw, i am now into suspension wash.. I remove each tire, wheel clean it, then degrease the susppension system supported by 3 jacks. Hirap na kasi baka gumalaw habang nag-detail ako. Maipit kamay ko
    So far i did 12 wheels na or total of 3 cars. 3 suvs in particular. It was a great excercise.
    Ang sarap sarap ng feeling na meron ka nagagawa na hindi nagagawa ng iba or others fear it,
    All i can say is recommended ko ang suspension wash, parang naging-soft sng takbo sa ilalim by removing all those sticky mud snd grime and grease thru the years
    While you're at it, get a brake dust cleaner na din to melt those brake dust na nakadikit sa wheels and suspension nyo
    So fulfilling : engine wash and suspension wash
    Oct 2009
    #72
    masarap din ang feeling kapag bagong car wash,engine wash,at under wash,pagka tapos kakain ka,after kumain.maliligo.mag shave,at tooth brush..
    pagka tapos saka ka sasakay dun sa sasakyan mo.kahit hindi umaandar.or kahit kaunting ikot lang sa subdivision mo.para bang hinehele ka dun sa loob ng sasakyan mo.ang gaan ng pakiramdam.
Engine wash
