Page 3 of 3 FirstFirst 123
Results 41 to 60 of 72
    Sep 2014
    Quote Originally Posted by red_one View Post
    If takot sa tubig, you can always go back to "waterless" method or the old "wet towel" method. Yan ang sure na walang mababaha ng tubig.
    Sent from my D5833 using Tapatalk
    i tried that red using spray bottle. sobra hirap. the spray bottle doesn't have enough pressure to wash off the degreaser. and also those hard to reach areas like connectors.
    pag pressure washer kasi mas effective.
    1. spray pressure washer
    2. spray degreaser
    3. agitate those parts na heavy ng grease with a paint brush
    4. let it sit for like 10 minutes
    5. then spray again, the pressure from pressure washer really removes both the melted grease and grime as well as degreaser
    with the spray bottle method, you'll need rag to clean up and sometimes, if heavy ang engine grime, lalo lang kumakalat.
    what's your technique ba with this?
    Aug 2012
    2. spray degreaser
    Hindi naman ako nahirapan. Meguiar's Engine Degreaser ang gamit ko.
    Anong degreaser ba ginamit mo?
    Agree bro
    Weird, engine degreasers make mud extra soft. But you have to wipe and wipe though. Not sure why hirap si mini
    Mini ano ba nililinis mo? Pampasaherong jeepney na galing ng farm?
    Apr 2012
    for me, i used the degreaser na nabibili sa D-I-Y, effective din naman at mura pa.
    i put in a spray bottle then gamit lang ng paint brush to agitate yung dumi. for hard to reach areas, dugtongan ko lang yung handle ng brush ng stick para humaba at maabot ng brush then wash na. after apply ng dressing, malinis na ulit engine bay...
    Oct 2015
    Bakit wala ako makitang meg's degreaser. Naka ilang Ace Hardware nako, tsk dalawang Blade shop. $3.99 lang sa autogeek yung 32oz na bote nito. Magkano ba to satin?
    anu yung MAF na kelangan din takpan? dami pala tatakpan. Yung compressor nung kotse ko nasa dulo sa baba pala, pwede nmn mabasa siguro yun, di nmn din sya tinakpan nung nag pa engine wash ako dati. Yung battery mas okay bang tanggalin nalang?
    My car got an engine wash from the casa for the first time on its 6th yr. Luckily they did a good job naman.
    Aug 2012
    Tide Ultra.. Hindi lang pang-labada, pang-makina pa.
    I just use Gunk Foam degreaser. It really clean the engine fast. After 10 minutes tapos na ang engine cleaning. I just let it dry before using it.
    Meron Sa mga talyer sabihin niyo lang. Gaas pa wash Nila tapos yun water after. Meron sila attachment lagayan ng gaas and water para doon Sa air compressor Nila after hanginan pa Nila.
    the only part i cover is the alternator and ecu. then i just use a very strong mix of joy, spray on, wait a few minutes, then rinse off using a pressure washer. syempre common sense, pag nakita mong electrical e di don't spray directly especially sa mga terminals. masisira lang electricals mo pag nababad, like kung direct yung spray mo ng water at pasukin sa loob, or flooded. for battery terminals i brush with soap (joy), then rinse with ordinary water, then coat with silicone electrical grease or spray.
    gusto mo water proof ang electrical connectors and terminals? diy, lagyan mo ng electrical heat shrink tubes. i started doing this on my bt50 before but never finished.
    last month i got refused at the car wash again! pagkakita pa lang nila sa malagkit na putik they waved me away hahaha! inabot ako 3 hours magtanggal ng putik
    Usually ayaw nga ng mga carwash sa mga maputik/galing offroad hehe
    Sep 2014
    Graduate na ako sa engine wash and detailing, I did 5 cars for the entire july. Dami ko fears na na surpass.
    For instance, umusok ang maitim ang engine ko and my aircon clutch got shorted. I though i broke my car, pero umayos din
    Engine cleaning is an art.
    Btw, i am now into suspension wash.. I remove each tire, wheel clean it, then degrease the susppension system supported by 3 jacks. Hirap na kasi baka gumalaw habang nag-detail ako. Maipit kamay ko
    So far i did 12 wheels na or total of 3 cars. 3 suvs in particular. It was a great excercise.
    Ang sarap sarap ng feeling na meron ka nagagawa na hindi nagagawa ng iba or others fear it,
    All i can say is recommended ko ang suspension wash, parang naging-soft sng takbo sa ilalim by removing all those sticky mud snd grime and grease thru the years
    While you're at it, get a brake dust cleaner na din to melt those brake dust na nakadikit sa wheels and suspension nyo
    So fulfilling : engine wash and suspension wash
    Oct 2009
    masarap din ang feeling kapag bagong car wash,engine wash,at under wash,pagka tapos kakain ka,after kumain.maliligo.mag shave,at tooth brush..
    pagka tapos saka ka sasakay dun sa sasakyan mo.kahit hindi umaandar.or kahit kaunting ikot lang sa subdivision mo.para bang hinehele ka dun sa loob ng sasakyan mo.ang gaan ng pakiramdam.
Engine wash
